Colour print out distorted - C352
  • KM7155
    • Aug 2008
    • 145
    [Misc] Colour print out distorted - C352
    Hi guys, anyone can help? (refer to picture)
    the print out is individual IU print out.
    any input will be much appreciated.
  • agudmove
    • Jun 2009
    • 70
    Re: Colour print out distorted - C352
    I can't tell from the angle of the picture if the black printout has the same problem. If it does check image transfer belt, change it to eliminate it as a problem.
    • mikeena
      Branch Technical Manager
      • Mar 2007
      • 219
      i i agree if image problem is same across board it can only be a few things 1 is the image transfer belt 2 is the transfer roller 3 fusing unit. can imagine fusing causing this type of issue transfer roller and transfer belt are the two i would focus on. i believe (i could be wrong) i have not work one in 3 months i think the transfer roller comes with the transfer belt. but it could be the housing. run gradation again and try to stop the printing once it hits second transfer. this way you could see if the problem occurs before and after at the second time. i try to open machine as it is half way through
      • copier tech
        • 8132
        Check the transfer roller mount bracket, they can crack, especially at the rear, then the transfer roller doesn't sit correctly.
        โ€‹
        • KM7155
          • Aug 2008
          • 145
          Thanks guys for the input, will be onsite in few days time to rectify the problem,
          will bring the transfer belt and transfer roller along as well.
          will update u...
