I have a Faint yellow back ground on a Konica Minolta C550
Re: Faint yellow back ground
We are not here for helpless end users; however, I will tell you that the setting is in service mode and if acquire a service manual, you should be able to find it easily.Comment
just saw the settings, but dont know how to play with them,and remember english is not my first languageComment
To make the background level foggier, decrease the setting value.
To make the background level less foggy, increase the setting value.
^ Regardless, of your understanding of English, simply play with the numbers--you can always change them back if they do not work.Comment
okey, i get you, but for my problem,i guess the problem is on the board and need to be replaced, the technician tried to fix the board and all the problem started.Comment
