Biz Hub C552 IU CIAN, loose developer
Re: Biz Hub C552 IU CIAN, loose developer
I have had the same issue< on the black dev unit there is a cover that goes over the top of it, if this is missing i have had toner dusting ( black toner) going onto the main charge grid on the cyan process unit , this will up the charge in that area of the drum which pulls the cyan dev out,look at the cyan process unit on the grid qwith a torch and see if you can see toner on it, also black toner around the front of the cyan unit< if you have changed the black dev unit recently you have to take this part off and put it on the new unit>
let me know if this is of any help.
Cheers -
I had this issue on a few machines, I think now I have fixed it by adding extra pads to the cyan locking leaver.
Also you can empty out the dev from an old unit & pour it into the one that has lost dev, simply pour it down the toner shoot on top of the IU, I started to carry a container of old cyan dev it was very usfull for a quick fix as replacing the cyan IU after less than 10k was expensive!Let us eat, drink, and be merry, because tomorrow we may die!
โComment
