Print quality issue Bizhub 423
  • wseyller
    • Sep 2012
    • 1129
    Drum, dev unit, and developer have been changed. See pdf attachment. Asking this for another KM tech.
    SKM_C364e14122415350.pdf
    • 22939
    Re: Print quality issue Bizhub 423
    You haven't said if this is a copy of a gray original, or a gray print.
    I'm guessing that those bars are crossfeed, not in the feed direction. I suspect that you have a registration drive problem. The paper stalls, yet the drum keeps moving. You end up with image compressions.
    Personally, I'd check the registration roller bushings. I've seen the registration roller bushings ovalled out, and the grease turned to tar. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2028
      Could be fuser all scored up
      Pretty poor post for a tech of your stature wyseller
      • wseyller
        • Sep 2012
        • 1129
        Its a grey print 11x17. And the pages have been folded up some and damaged a little. Mainly the black bars but it is also inconsistent throughout. I told the tech to do a half stop test and see if issue occurs before fuser. Sorry for the poor post. Its Christmas eve so I've had a lot on my mind. Just wanted to see what you guys thought.
