Does anyone know if a wireless network adapter (usb) can be plugged directly into a C360 to allow various computers in the building to print and scan?
Wireless Network Adapter
Tags: None
Re: Wireless Network Adapter
Try it and let up know...you can also run a Ethernet cable from the MFP to a wireless access point, looks like wireless printing to any end user. The newer 3 series have the UK-208 (built in wireless adaptor) if upgrade is an option. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals. -
Netgear makes a nice little wireless adapter, that you connect to the wifi and then via cable to the copier for wireless access. wnxx 3001 I beleive. They work well................and their not expensive.......................Mystic Crystal RevelationsComment
The good news is that a bridge or even a range extender costs very little more than a USB wireless adapter.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
What Kenb said...
Yeah the copier would need a driver and os functionally to be able to use it so answer is NO. I think wireless on a copier is not the best idea unless there is just no other way. I see businesses spend thousands on a copier and don't want to spent a little money running a network drop. If you need wireless then buy a network bridge to transform wired connect from the copier to wireless.Comment
