Dead potential sensor
  • chromos
    • May 2025
    [Jamming] Dead potential sensor
    Hi everyone,
    I have a dead potential sensor o bizhub 6500. New part is coming in 7 days and i wonder how can i adjust
    the mashine manually. (auto gamma adjust, calibrate colors etc)
    • 22942
    Re: Dead potential sensor
    I used to use this procedure on high volume Canons when the potential sensor failed.
    I specifically remember how in class, the instructor told us how sensitive the potential sensor is. So when I had a high volume machine with a dead drum potential sensor and a week to wait, I took a chance.
    On these machines you could always turn off potential control, and the machine would use certain default values that were close enough to get a decent copy. So I had a fallback position if it failed.
    After cleaning the DPS several times to no effect, I rapped it smartly with the back of my screwdriver. If you're so darn sensitive, take that! To my surprise it worked for a week until I returned with a replacement. It's worked on at least 6 occasions on various Canon models, for varying periods of time. As little as a few hours ... up to 2 weeks. =^..^=
    • Mick01
      • Nov 2012
      • 362
      You can try this temporarily which may get the machine operational until you replace the sensor
      Turn switch 24-2 to on
      Turn switch 25-3 to on
      Turn switch 25-4 to off (should be off already but check)
      This should temporarily disable image process and colour registration control.
