bizhub 600 jaming in duplex showing j1701
  • Naveed Shahid
    • May 2008
    • 162
    hello every one
    bizhub 600 jaming in all trays once try to make duplex its showing j1701 if i try A4 r no jaming but A4 Always jaam if i try 3 copy its ok more then 3 put its jaming and showing j1701
    regards
  • allan
    RTFM!!
    • 5459
    Re: bizhub 600 jaming in duplex showing j1701
    Did you remove the mylars from the duplex entrance. There is pinch rollers you can feel underneath the left side of the ADU remove the u channel and take of the mylars.
    Sometimes the whole clear plastic tray needs to be removed disassembled and cleaned there is a black selector gate that also gets sticky or the spring pops of.
    in your case i think its the mylars because SEF works.
    Whatever
