Hello to all,
on a bizhub 601 with finisher, the customer must push 3 times the button to get a copy when copying from the glass plate.
Only when I switched in menu "Output" from "sort" to "group", it's sufficient to press the start button only once to get a copy and will be printed immediately.
But this has the disadvantage in ADF mode, the copies are now grouped and not sorted.
Is there really no way to adjust the machine, that a copy over the glass plate is possible through one easy press of the start button and "Output" Mode in "Sort"-Funktion?
