bizhub C 550
  • tomislav
    • Nov 2011
    • 30
    bizhub C 550
    Hi,
    I have Konica Minolta bizhub C 550 with error P-14,but when I change the IU (black) P-14 is gone.
    The real problem is that the copier won't give me Blue light on START button (blinking red).
    Can anybody help me?
    Thanx
  • Cookr
    • Dec 2011
    • 184
    • Synaux
      • Mar 2012
      • 1224
      Re: bizhub C 550
      There are a few p-14 bulletins for these machines:
      P-14 at power on and after stabilization runs. Performing the color alignment adjustment does not correct the
      problem.
      Solution
      CAUSE: Failed print head relay board.
      SOLUTION: Replace the print head relay board (p/n A00J H003 00).
      ^ There are 3 ICP chips that can blow on those--pretty common in my experience.
      There is a firmware to rectify the p-14 error in my region it is Ver.GC1-22
      • tomislav
        • Nov 2011
        • 30
        Re: bizhub C 550
        thank you ,
        i'll try this tomorrow and post the result
        thank you
        • tomislav
          • Nov 2011
          • 30
          Re: bizhub C 550
          Nothing,i run all that you say,but the START button still blinking RED.
          HELP
          • Synaux
            • Mar 2012
            • 1224
            Re: bizhub C 550
            HELP
            Really? You replaced all the parts listed in the bulletin that I posted and installed that firmware??
