GREETINGS to all TEC
The patient is bh 162 whit 45k on counter. Didn't change nothing jet.
Machine was serviced periodically 10-15k.
5k before(about 20-25 days) costumer called me becoze strange sound in machine and dirty picture. I checked machine and saw that waste toner where blocked in the tube on the developer. Developer aug roller couldn't pull the waste toner into the mixing chamber witch resulted blockage of whole system. I cleaned the blockade and pushed some of the waste toner into the chamber.
After turning and testing the machine i got a dark,strong picture whit millions of dots over whole picture( shadowing). VG adjust didn't help so i did an ATDC adjust. I got number over 155 witch is bad as i saw by picture.
I removed toner bottle and did a 80 of black copies and after i did ATCD again. Value was 135. Picture where fine but not excelant!
Costumer called me again on present day and told me that picture is bad.
I inspected the machine, and saw again same problem. I took myne whole IU and placed it instead costumers IU and to take it to service. Machine at booting reports C0f32( broken ATDC) but only whit myne IU. So i thought IU was wrong and placed another IU, also myne but same problem.
I inspeced gears and no damage.
I saw on bizhub 163 that they placed a plastic pad where waste toner enters the developer
Can i fix anything in here whit software reinstal?
Did anyone experienced this and is there a solution
My dear colleagues THX AHEAD!
