843.99 on the X73
  • Iowatech
    Not a service manager
    • 3930
    [Error Code] 843.99 on the X73
    For what it is worth, I found out today that this error code is probably is due to dirty sensors in the document feeder.
    • 23006
    Re: 843.99 on the X73
    Yes. If you search you can find a Lex bulletin about it. Essentially, there is a sensor in the DF top cover that looks a little like a thermostat. It's easy to miss since it's dark gray, in a dark gray housing. All I had to do was clean the surface. =^..^=
