Bizhub c353
  • dstana
    • May 2025
    Bizhub c353
    We recently acquired this printer and it seems to be missing some settings. I need to set a static IP address but am unable to access the administrator settings.
    The user manual says to access "administrator settings" by pressing the "Utility / Counter" key and it should display there as option 3. It's just not there.
    Are there different user accounts that limit access to different options for this device? If so, how do I get admin access?
    Thanks in advance for your help.
  • wseyller
    • Sep 2012
    • 1129
    Re: Bizhub c353
    The administrator option will be hidden for certain reasons such as print/fax job in progress. There may be other reasons. You may want to access service mode just initialize the device to wipe everything.
    • dstana
      Re: Bizhub c353
      I checked and I do not have any print / fax jobs in progress. How do I access service mode to wipe the device? Thank you for the quick response!
      • Kapral
        • Oct 2012
        • 43
        Re: Bizhub c353
        Information about how to get to service mode is contained in service manual.
        When in service mode You click "System 1", then "Initialization", "Data Clear", and press start.
        Afterwards You turn the machine off and on, and it should be good.
