dedicated surge protector...
  • SmellsHot
    Head Tech
    • 512
    Not sure what everyone calls the plug, but we call it a dedicated 20amp......Basically it's the one on the Konica 554e. It has one vertical and one horizontal and a ground.....
    I cannot find any surge protectors for these.....We use to use isobars....
    Any suggestions?
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
  • Ctl-Alt-Del
    • Jul 2006
    • 430
    Re: dedicated surge protector...
    Any suggestions?
    I've been buying from ESP for years, they will have whatever you might need: http://espei.com/products/esp-digital-qc/
    • Synaux
      • Mar 2012
      • 1224
      Any suggestions?
      This is the plug you are talking about right (Nema 15-20r)
      I simply order the adaptor I posted and use the typical ESP protectors.
      Hope that helps...
        • 23008
        5-20R? Like this:
        Use ESP D91424T:
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          We help you acquire the perfect domain for your site. Affordable payment options. Quick and responsive customer support available.
          They have these in 15 & 20 amp models. They're affordable and pretty dang cool. Call Todd Emery for pricing.
          We've started using them and have been very pleased.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • mmru4real
            • Aug 2008
            • 67
            Originally posted by tmaged
            http://www.memoryexpertsinc.com/products/mx-power/
            Todd is great to deal with and if you order over a certain amount you get a nice discount also!
            • SmellsHot
              Head Tech
              • 512
              Thanks everyone for the suggestions......
              • Frostwolf
                • Apr 2008
                • 71
                We stop using the ESP, the older models were passing electrical noise into the Fax lines when connected to C353 series.
                We went to SmartPower filters here ... http://www.smartpowersystems.com/con...uardianII.html
                Smart power has been pretty good, a few have failed with noise problems.
                Innovolt's have caused an issue when the power drops out, and caused our machine to lock up.
                I will look into those MX Power brand, those look nice.
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  Originally posted by Frostwolf
                  We stop using the ESP, the older models were passing electrical noise into the Fax lines when connected to C353 series. We went to SmartPower filters here ... http://www.smartpowersystems.com/con...anII.htmlSmart power has been pretty good, a few have failed with noise problems. Innovolt's have caused an issue when the power drops out, and caused our machine to lock up. I will look into those MX Power brand, those look nice.
                  The older ESPs didn't work on GFCI circuits either.
                  • nmfaxman
                    • 1702
                    You can make a pigtail connector in the meantime.
                    Female plug matches output plug of machine, male plug matches suppressor.
                    Use a thick AC wire to avoid heat problems.
