Error code C-D012 on C654e
  • ni311
    • May 2008
    • 658
    Hello,
    I am receiving this error code right after installation. The Scan/Fax and Box is remaining in 'Preparing' and the network setting button in Admin section is hidden. Looks like a hard-disk error, I try to format it but the code remains. Any ideas?
    Thanks.
    Konica Minolta Error Codes - Explanations and Solutions
  • solidzdawg
    • 71
    Re: Error code C-D012 on C654e
    Newest FW solves most of these erratic behaviors
    make sure you logical format HDD AFTER FW.
    Peace
    -Z
    • ni311
      • May 2008
      • 658
      I'll try this too.
      The fun part is to explain to the customer how come a brand new machine is going directly into error codes. And even more, the code is not in the service manual... how cool is that...
      • solidzdawg
        • 71
        Its horseshit i had to fight one to get on Equitrac (an external server/print as you go-tracking bs) without it locking up..
        These are 4 gen "E" models? PLLLLLEEEASE
        E is for Erratic, someone said that recently on here and I agree.
        -Z
        • wseyller
          • Sep 2012
          • 1129
          Originally posted by ni311
          I'll try this too.
          Try replacing the entire machine due to SSD board failure at one month. Second machine after one month then also has failed SSD board which we replaced the board and updated to recommended special firmware. And now after couple weeks ssd has failed again. All the same customer.
          Sent from my DROID BIONIC using Tapatalk
          • ni311
            • May 2008
            • 658
            Ok, the issue was solved like this: after replacing the factory hdd with several hdd and various formats, the code was the same; I re-write the firmware and after this I got mfp error code; after this, I deleted all the settings and re-did all the installation steps. It is working and I hope it will stay this way because I'm sick of it :/
            • solidzdawg
              • 71
              Just to clarify,
              After you deleted all the settings, what installation steps did you use?
              Just wondering so I know how to fix this same issue im having..
              -Z
              • ni311
                • May 2008
                • 658
                I took the installation manual and did all the steps from there, like for a brand new machine. It worked for me.
                • CopyJunkie
                  • Oct 2012
                  • 28
                  Regarding the SSD board failures, Bulletin #: 9103 addresses this.
                  To disable power consumption, use these steps.
                  Menu  Utility  Administrator Settings  [Enter Password]  System Settings 
                  Power Supply/Power Save Settings  Screen 2/2  Power Consumption In Sleep Mode
                   DISABLE.
                  Press OK to save the change.
                  Heard there is firmware in the works to fix this but this is a temporary preventative measure. From my understanding your still screwed if the machine is stuck in a constant reboot or displays MFP=NG when loading firmware.
                  NOTES ON HOW TO USE THE FAX MACHINE.
                  1. Get into your DeLorean (or your TARDIS) and go back to 1990.
                  2. Place papers in the machine - Face Down.
                  3. DO NOT dial 9
                  4.
                  Rejoin the rest of modern civilization.
                  • wseyller
                    • Sep 2012
                    • 1129
                     DISABLE.
                    Yeah we know of this bulletin. They have revised it about 7 times. We have been waiting for a permanent fix. Because those workarounds like power consumption settings and such don't always solve it.
                    • emujo
                      • Jun 2009
                      • 3009
                      It's looking like these erratic codes are being caused by communication errors. The SSD bd, HDD and MFP communicate back and forth with each other and if anything goes wrong you get these errors. If your MFP is working print out the list print and look on the last pages for some odd looking alphanumeric abort codes and instantaneous failure codes. If you are getting these, and you feel lucky, de-install the HDD, format the SSD board, re-install HDD and format (logical on both), then do a complete data clear. You will have to re-enter a lot of settings, so keep track of LK info, vcare, network settings and so on, and of course re-load of firmware and movie data. Sounds like a lot, but if the SSD board goes bad you will be doing this anyway. Another trick (if you can get the MFP to come up) is to hold the power save button and power on. This will force the diagnostic mode to run and you can see if you are getting any other kind of failures. EMujo
                      If you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.
                      • Darw28
                        • 14
                        • emad romimah
                          • Dec 2017
                          • 3
                          I want to firmware for bizhub c754 please
                          • Synthohol
                            Certified Konica Expert
                            • Mar 2016
                            • 5847
                            more candles being burned here.
                            • copier tech
                              • Jan 2014
                              • 8174
                              Firmware Update - Printer & Copier Firmware
