ir5055
  • akm
    • Sep 2012
    • 155
    [Jamming] ir5055
    Dear/Copy techTeam,
    Please i want your help in the problem with IR 5055 that display jam when i use the right deck although i changed the pick up ,feeding ,sep rollers. when remove the jammed paper and try another it stop in the same place. the jam code 0107 ps32
    thanks
    akm
  • teckat
    • 16083
    Re: ir5055
    Originally posted by akm
    Dear/Copy techTeam,
    thanks
    akm
    Information on DECK 0107 Jam Code
    0107: Right deck pull-off sensor delay jam
    replace the Pick-up Inlet Guide
    (has Mylar) and
    the Separation Plate (has Mylar) / FL3-3134-000 and FL3-3135-000 respectively.
    010B-010C-010D-010E-0107-0108 Jam Codes.pdf
    photo above shows an example of the pick-up jam (down-curved paper jam at the leading edge of paper) [A] at the separation roller.
    • copier tech
      • Jan 2014
      • 8144
      Re: ir5055
      If the above doesn't work & machine has a high count, say over 2 mill, I would replace the right deck feed ass'y
      • akm
        • Sep 2012
        • 155
        Re: ir5055
        (has Mylar) and
        [ATTACH]24409[/ATTACH]
        [ATTACH=CONFIG]24410[/ATTACH]
        very thanks for your rapid help i will order the spare parts and install them and i will tell you the result
        thanks
        akm
        • canonbundy
          • Jun 2012
          • 607
          Re: ir5055
          Dear/Copy techTeam,
          thanks
          akm
          Remove the Feed Assy & lube the 1 way Clutch/Gears (3 of).
          • akm
            • Sep 2012
            • 155
            Re: ir5055
            (has Mylar) and
            Dear/Eng.Teckat
            i change the sep.plate fl3-3135-000 but still the paper jam the code 0102 i send a copy of jam
            thanks
            akm
            • teckat
              • 16083
              Re: ir5055
              Dear/Eng.Teckat
              [ATTACH=CONFIG]24427[/ATTACH]
              thanks
              akm
              jam - 0102
              Paper Stock Assembly lift plate does not lift evenly.
              Uneven lifting is due to deformation of the Rear Support which houses the pulley for the lifter cable
              Part numbers:
              Rear Support: FL2-3081-000
              Pulley: FC6-3767-000
              • copier tech
                • Jan 2014
                • 8144
                Re: ir5055
                From your picture I would replace the clutch that drives the vertical path roller, the clutch in the right deck ass'y, it looks like it could be slipping the paper isn't reaching the pre registration sensor.
                Or failing that like I said in previous post, replace the right deck ass'y if machine has a high count.
                What count does the machine have?
