DIY Auto shares
  • allan
    RTFM!!
    • 5462
    #61
    Re: DIY Auto shares
    Was having a nice day until the lock on my ignition decided to fail. Steering lock on...
    One way to get stranded.
    Whatever
    • Iowatech
      Not a service manager
      • 3930
      #62
      Re: DIY Auto shares
      While I've never had the lock itself fail, I've had worn keys simulate that problem. Usually by ignoring the obvious signs of having to move the steering wheel around before the key would turn.
      • ZOOTECH
        Senior member of CRS
        • 3375
        #63
        Re: DIY Auto shares
        Yep, have seen this - you have to pull the wheel hard to one side and try the ignition again.
        • allan
          RTFM!!
          • 5462
          #64
          Re: DIY Auto shares
          Luckily i got the barrel removed. There is a tiny little pin that makes it lock. I removed that and resembled the thing so i looks and work alright but just about any thing that can go in the hole will turn it.
          Well the coded key will stop anyone from taking it.
          Whatever
          • Iowatech
            • 3930
            #65
            Re: DIY Auto shares
            Mother's Aluminum and Mag Wheel Cleaner can be used to polish haze off from plastic headlamps.
            It also works well for cleaning stainless steel kitchen sinks, or at least it did well on mine. Some elbow grease was needed for that, though.
            The paste worked better for me.
            • NeoMatrix
              Senior Tech.
              • 3513
              #66
              Re: DIY Auto shares
              RE: Clean Stainless Steel :
              75% Hydrochloric acid & 25% water on a damp cloth, or spray bottle; cover all over the bowl of the stainless steel sink. Wait a few minutes, then wash clean with plenty of water. The stainless steel should look like brand new.
              Repeat the above every 12 months if needed.
              You can also clean cast iron and iron plates with 75%-100% hydrochloric acid, but you need to stop the acid iron reaction with a wash of alkaline Hydradrated lime mixed in water. If you don't stop the acid iron reaction the metal will get a rust coating all over in a very short amount of time.
              Make sure you do the above out doors or wear a suitable breathing mask.
                • 14728
                #67
                Re: DIY Auto shares
                I think I will just use Comet. It works great and won't burn me or wreck my lungs.
