leaving to join an asylum for my own health😡
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    i feel as though I've opened up Pandora's box. Started off with a cracked port in the controller pwb. Fitted & ordered 4x pcu(pm due) 2 arrived damaged and 1 giving lines out of the box. Ordered again, another turns up bust & now it's clogged up the transfer waste unit & damged the waste pipe seal.
    ok fitting a pipe is a bitch with every cover practically removed, new Image transfer belt unit & cleaner fitted. I've had issues fitting a new ITB unit not turning so I turn it manually before fitting - bastard belt has now shredded!!!! Not even 1 copy yet
    Incontinentia Buttocks
  • ss12
    • Jul 2008
    • 289
    Re: leaving to join an asylum for my own health😡
    Ricoh 03 range by any chance? If it is ,been there done that got the t-shirt
    • ZOOTECH
      Senior member of CRS
      • 3375
      What a f'up way to end the week - I feel for you.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        How did you guess😔 The money pit! Hate every part of it!
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          glad the weekends here - away from the mettis turdlings!
          • qbert69
            • Mar 2013
            • 1152
            I think we all agree that the effing titanic named Ricoh needs to sink!...I'll take a Kyo any day over a Ricoh!
            With Ricoh, it's "same shit, different day"!...they don't learn from their damn engineering mistakes (...shitty engineering!) or overengineer shit so much that the "weakest link" in the chain of "checks and balances" takes the whole fucking system down!
            DOH!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              DOH!
              Best bit is the tech helpline won't talk to you unless you're a supervisor & above or maxed out every fucking training module on the site.im on a course soon and I'm expected to bust my ass passing it yet in the event I need help in the field I can't fucking talk to them 😡 Fucking cretins!
                • 23008
                Other than dumping toner like crazy, I kinda liked the Ricohs in the 90's. They must have slipped a little since then.
                It's sounds like you had a hell of a day. For me, other than being yelled at for no good reason, the calls have been easy. =^..^=
                • Lagonda
                  • Aug 2008
                  • 1649
                  Chill out Bishop, it's the weekend, it's going to be at least 72 hours before you see another copier.
                  And remember if alcohol isn't the answer you're not asking the right question!
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    Got any spare going?
                    I blame debs for this turbulent time as she must be to blame for something😉
                    • banginbishop
                      grumpy old git
                      • Oct 2007
                      • 894
                      Started off ok until again a mettis turdling gave the customer an excuse to bite me. Fitted a side unit FOC but the machine faulted out 2 days later with an intermittent line? Turns out the customers pissed because it's being over used so I got the flak! Charming I must say.
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Sorry, it's been a long hot summer and I'm down to my last 3 dozen bottles of home brew. Barely enough to keep me going until the weather cools off enough to start brewing again.
                        Don't know how you can blame the Delightful Debs for your run of bad luck, thought she would more likely to wave her magic wand and put some sparkle in your life
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          Re: leaving to join an asylum for my own health��
                          Only 3 dozen bottles left, you can't be under too much stress then. Are they large bottles or stubbies ?
                          The weather appears fine for Brewing, I've put down 3 brews over the last 3 weeks.
                          First brew was a bit weak, but the last two have been going okay. I have another one brewing at the moment. I should get to it sometime this week.
                          With all the rain around you should be getting cooler weather down your way.
                          • ZOOTECH
                            • 3375
                            I applaud your efforts at a home brew; one of our techs does the same, and I gratefully accept his 'donations'.
                            • Lagonda
                              • Aug 2008
                              • 1649
                              Have always brewed longnecks, you have to work twice as hard for stubbies.
                              Since we down sized to the current house we don't have the room for a gutted out fridge to keep the brew keg at a stable temp so just have to wait until until the ambient temp drops a bit or the yeast reacts to fast and you get a crook tasting batch. My current favorite is Coopers Australian Bitter with Super Alpha hops and 1 kg of dextrose and light malt booster.
