flashback
  • blaze2000
    • Sep 2010
    • 232
    flashback
    OK so I'm leaving the copier business after a decade or so. Going through my drawers and toolbags I found all sorts of interesting things. Check this out, I don't thinkWP_20160604_01_23_26_Pro.jpg I'll be needing this anymore! Take care guys, time for me to go IT.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: flashback
    Originally posted by blaze2000
    OK so I'm leaving the copier business after a decade or so. Going through my drawers and toolbags I found all sorts of interesting things. Check this out, I don't think[ATTACH=CONFIG]33285[/ATTACH] I'll be needing this anymore! Take care guys, time for me to go IT.
    Yeah, I've got a few items like that, including the corona wire spool; good luck with the IT side of things - it's a cutthrought business. Some of the IT folks will keep secrets on how their networks are setup, and thusly will have knowledge that will keep them in a job.
      • 23009
      Re: flashback
      The last wire spool I had of that type crumbled into opaque bits plastic. =^..^=
      • Iowatech
        Not a service manager
        • 3930
        Re: flashback
        I've still got a roll of Sharp corona wire in the toolcase. It was my goto for any wire replacement for quite some time, and I keep it handy for emergency repairs. I haven't had to replace just the wires for a while though.
        I used to have a spool of gold plated Canon grid wire which was easier to use because it was thicker, but I haven't seen that in close to a decade.
        Heh, back in the day when the wires were platinum coated, when I replaced the wires I'd save the used ones. Then I realized that the plating was probably only a molecule or so thick, and as I cleaned the wires with an eraser I'd likely already wiped out the coating anyway.
        • copiertec
          • Jan 2016
          • 2211
          Re: flashback
          Ah... the lost art of stringing corona wires. I still have a flat-blade screwdriver with a little notch in the middle that I used to string wires back in the day, I found it worked much better than the corona tool that came in my tool box. Enjoy your sabbatical from the copier tech side of the business.
          • ZOOTECH
            • 3375
            Re: flashback
            Ah... the lost art of stringing corona wires. I still have a flat-blade screwdriver with a little notch in the middle that I used to string wires back in the day, I found it worked much better than the corona tool that came in my tool box. Enjoy your sabbatical.
            I modified the spring hook (other side of the hook-don't know if it has a name) to be able to push the wire below the screw to tighten it down.
            • copiertec
              • Jan 2016
              • 2211
              Re: flashback
              I did the same thing, Zootech. I found the gap too big, to get down around the screw, so I added some JB Weld to it, to shorten it up. I swear I could string a corona wire in about a minute or less, with proper tension and no burs on either end, to avoid any vibration or arcing... good times. I always hated when the spool would sit in my bag and come unraveled inside the container because I lost the red plastic holder piece at some other call prior in the week.
              • NeoMatrix
                Senior Tech.
                • 3513
                Re: flashback
                RE: Spring hook and a roll of corona wire.
                Use the hook end of your spring hook to twist a loop in the end of the new corona wire, by rolling the metal spring hook in your fingers 5 or 6 twists. Using your fingers force the loop down the tapered shaft of spring hook until perfect larger loop is formed. Remove the loop off the spring hook an place under the screw on the corona electrode and tighten down. With one end of the corona wire screwed in place, measure out the corona wire with the tension spring insitu on the corona frame and twist one turn around the end of the spring eye. Flip the tension spring off the corona frame and twist the entire spring multiple times through your fingers until the corona wire is firmly fixed around the end of the tension spring. Snip the unused corona wire off the roll next to the spring, and then fit the completed wire and spring back into position on the corona frame.
                The above also works in reverse. You can twist the tension spring onto the new corona wire first, then measure out to the other end of the corona frame wrap the new corona wire under the electrode screw tighten down and then snip off any excess wire.
                Either Or works, depending on the corona frame an ease of access.
                • ZOOTECH
                  • 3375
                  Re: flashback
                  "Old School" - you have been around the block a few times, right?
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    Re: flashback
                    ...Yeah, One or two rolls of corona wire later.
                    I never liked stringing entire multi strand corona grids, the single electrode was ok but the grids I would put off for as long a possible.
                    Some of the old canons took half a roll of corona wire per grid. I tried to leave the grid maintenance for the other techs.
                    I though I would share my last post for all the younger blokes Techs who might get a nugget or two of info out of it.
                    • charm5496
                      • 2387
                      Re: flashback
                      We still teach our noobs how to string wires as we have some out there still require it. It is an art to do it correctly IMO, and some folks have a hard time with it. Working on the Canon CLC production devices all day long you get really good stringing wires as they had 11 that needed replacing at every PM cycle.
                      • subaro
                        • Oct 2010
                        • 1274
                        Re: flashback
                        Perfect description on how to string those wires. bravo.
