how do you carry a 3000kg of photocopy machine up the stairs?
  • allan
    RTFM!!
    • 5459
    Re: how do you carry a 3000kg of photocopy machine up the stairs?
    Agreed is smells funny.
    Whatever
    • Step
      Senior Technician
      • Sep 2015
      • 42
      Konica Minolta pro 120 with all its peripherals weighs in at 1.8 tons.
      Sent from my D6603 using Tapatalk
      • allan
        RTFM!!
        • 5459
        shit still not a laser machine
        Copied from a KM 1 spec sheet??
        Machine weight
        Approx. 8,000 kg
        This is where floor loading comes in to play.
        If you can get it up there do you really want it there.
        Whatever
          • 22925
          #19
          I would be in trouble. I don't have 43 friends, and most of the remaining ones can't lift their own share anymore. Additionally you might be hard pressed to find 43 hand holds let alone 86 (for two hands). =^..^=
          • allan
            RTFM!!
            • 5459
            #20
            on average the guys lifting it would weigh in at 3.6 metric tons. It needs to be at least 15 meters counting all the sides.
            So say 6 meters long and 1.5 wide.
            That gives each guy only 350mm of space.
            Turning in a stair case could be a little difficult.
            Someone is going to die put you worst friend at the back.
            Whatever
            • Iowatech
              Not a service manager
              • 3933
              #21
              If there are acceptable openings on the outside of that building, I'd suggest using a crane. I used the crane on the back of my M816 for all sorts of stuff back in the day, it's not that hard.
              • NeoMatrix
                Senior Tech.
                • 3514
                #22
                Originally posted by terramobil
                I think 15 will not be enough. 60 are probably better. And then you will need to have bus to take them to the machine.
                ha.. yeah.. As a quick stretch and warm up exercise we could ask them all to pick the bus up for a bicept warm up...
                Who shouting dinner..... ?
                • habik
                  • 2013
                  #23
                  If there is no turning on staircase make a platform to counterfit the staircase and lift it the bugger the good old way by levering it bit by bit (or using jacks) until you reach the top level and then roll it across the platform. It will take forever but can be done.
                  Picture or projection of destination might be usefull.
                  Firmwares HERE
                  • mbcruzin
                    • Aug 2013
                    • 142
                    #24
                    Originally posted by aviso66
                    Lets say if you had a situation where there is no lift. Only to carry up to 2nd floor a 3000kg photocopy machine.
                    How would you do that?
                    One piece at a time.
                    True story: I actually did gut a brand new KMBS 951 pro. Just so we could carry it up to the 2nd floor. Then gut a Large Ricoh so it could be carried down.
