SC544 Fuse
  • copier tech
    • 8144
    SC544 Fuse
    Hi chaps,
    Quick question, is the mpc3002 & mpc3003 fuse the same?
  • Lagonda
    • Aug 2008
    • 1649
    Re: SC544 Fuse
    Hi chaps,
    Fuse?? You mean the little glass tubes with the fine wire in side that vaporises if you get it wrong?? Or FUSER, the large mechanical bit that gets hot?
    Sorry, they are two distinctly different types of fuser, not interchangeable.
    p.s. the Ricoh, Savin and Lanier thread would be a better place to ask.
    • copier tech
      • 8144
      Re: SC544 Fuse
      I was referring to the new unit detect fuse.
      • Lagonda
        • Aug 2008
        • 1649
        Re: SC544 Fuse
        Ah thats better! A tad more information and it all becomes clear.
        Sorry, don't know if the genuine fuser detect fuses are interchangeable, I've never tried it, just used the fuse that comes in the H/R sleeve box. However when I've had to fool a copier into thinking that its had a new fuser I've manufactured my own using a 125mA fuse from a local hobby electronics supplier.
        I hope that helps.
          • 37487
          Re: SC544 Fuse
          Yes. Whenever we have to replace a sleeve unit due to PM count, I keep the fuse that comes with it for when I have to reset a fusing error code.
          • copier tech
            • 8144
            Re: SC544 Fuse
            The reason I ask is we have a few 02's & 03's that keep throwing SC544, even though they have had new fuser sleeves replaced, thermopiles etc (I suspect a few of them are being pushed too hard)
            So i'd like to order a few spare fuses so the engineers can reset the error by replacing the fuse not the sleeve if it doesn't need it!
              • 37487
              Re: SC544 Fuse
              There was another thread that has some suggestions for other things to use instead of the fuse Ricoh provides.
              • qbert69
                • Mar 2013
                • 1152
                Re: SC544 Fuse
                ....just google PicoFuse 125ma....that should do it for ya!!!
                PS--I know on circuit boards they use 0 ohm resistors for smd fuseable links!
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
