ANY great ideas on how to quickly destroy hardware chips? Memory in particular?
  • mjunkaged
    • 386
    Okay, so we all fix stuff for a living, but our customers don't want their internal network or address data left on hardware chips (memory, network cards, copier main boards). Anyone have or used a great fast way to 'clear' or render untretrievable (without pushing buttions/ factory reset, we're talking lots of broken hardware) data left on chips? I'm thinking very high heat, but the smell would be a bit toxic!! CATTLE PROD??? Okay that's my pick!
    • 14821
    Re: ANY great ideas on how to quickly destroy hardware chips? Memory in particular?
    A hammer fixes everything
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      Soaking them in a bin of salt water should corrode them pretty well. They would be useless but not as much fun as a hammer or heat!
        • 23009
        I hope that you're not planning to resell these devices.
        They do make very effective door stops. =^..^=
        • mjunkaged
          • 386
          No, only obsolete stuff that's getting disposed of! Unless someone makes me angry!! Just kidding.....
            • 23009
            How about a plastic dish pan filled with 4 liters of Coca Cola? Have you seen what it will do to a steel nail? Phosphoric acid attacks most everything. =^..^=
            • mjunkaged
              • 386
              I wonder if it could eat the solder enough for the smd chips to fall right off the board? Try it , get back to us.....I gave up diet coke 2 decades ago, sugar coke 3 or 4!
                • 37533
                For Ricoh, remove the NVRam and HDD and hand them to the customer. Of course you need to charge for replacement parts you are going to h ave to install in order to make the machine operational.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Try a good, built tough, paper shredder for crushing the memory chips. A good shredder will crunch CD/DVD's without to much fuss.
                  • Vincent128
                    • Sep 2015
                    • 349
                    Yes, a forced air heat gun will strip a PCB clean.
                    Variable control easily adjusts heat level. Lightweight housing for comfortable all-day use. Heats up in seconds. 2-speed fan. ETL/C-ETL Listed. ULINE offers over 43,000 boxes, plastic poly bags, mailing tubes, warehouse supplies and bubble wrap for your storage, packaging, or shipping supplies.
                    also.
                      like it has been said... hammer time!
                      for HDD's I use a Philips head screw driver punching about 4-6 holes thru the casing and platters..
                      • spanky
                        • Sep 2012
                        • 468
                        Attach a ground to the ground pin on the chip and 24VDC on the other pins.
                        • Ctl-Alt-Del
                          • Jul 2006
                          • 430
                          Try a Hammer, if it's hard to access you can put an old Phillip's head screwdriver on the top of the chip and then use the hammer. All you really need to do is wedge something under the chip and pry it or a few legs off of it or break the board they are attached, no one is going to go though he trouble of rebuilding a chip to get someones fax address book.
                          Have fun smashing shit.
                          Or buy one of these:
