    • 29957
    #841
    Originally posted by skynet
    Phoenix has traditionally been one of the hottest places on the planet, so no calls for alarm.
    Temperatures in Phoenix hit 110-plus degrees for a record-breaking 31 consecutive days from June 30 to July 30, part of what was the hottest month on record for any US city.
    Apparently you failed reading comprehension
      • 878
      #842
      Skynet was stating a fact . You are making a idiotic comment
        You failed and continue to fail at basic literacy, however we know it's intentional.
          • 29957
          #844
          Another Florida educational failed student
          Yep the Fact he can't read and understand
          Got it
            • 29957
            #845
            Thanks ��
            Just remember it's fake heat
            Made-up by the media to trick U
              • 14553
              #846
              Just so you and the western journal aren't so confused I will explain something. Global warming is a process not an entity that travels the globe starting fires.
                • 16330
                #847
                I posted the historical data on climate change. There's a reason that no one should use this year as some sort of proof that the world is burning up or whatever. What happens if next year is cooler than expected? What does that prove? It proves nothing because it's a game that is played.
                  • 29957
                  #848
                  What if game OMG
                  Record Heat across the US
                  my cats are smarter
                    • 8153
                    #849
                    Global ocean temperatures soared to the highest level on record this week
                    The temperature of the planet’s oceans rose to new heights this week, setting a new record with no sign of cooling down.
                    The average global ocean surface temperature hit 20.96 degrees Celsius (69.7 Fahrenheit) at the end of July, according to modern data from the European Union’s Copernicus Climate Change Service, beating the previous record of 20.95 degrees Celsius set in 2016. The Copernicus ocean data goes back to 1979.
                    Scientists say the world needs to brace for ocean temperatures to keep rising as – the natural climate fluctuation that originates in the tropical Pacific Ocean, and has a warming impact – layers on top of human-caused global warming.
                    Kaitlin Naughten, an oceanographer at British Antarctic Survey, said the data from Copernicus painted an alarming picture for the health of the oceans.
                    “Other datasets may give slightly different values – for example, [the US National Oceanic and Atmospheric Administration] is reporting that last April was still very slightly warmer than now,” .
                    But what’s clear, she said, is “that current sea surface temperatures are exceptionally and unseasonably warm” and bringing wide-ranging implications, “especially for complex ecosystems such as coral reefs.”
                    Gregory C. Johnson, an oceanographer at NOAA, said sea surface temperatures have soared this year. “What we’re seeing is a massive increase. It’s about 15 years worth of the long term warming trend in a year,” .
                    The heat could increase even further. Surface temperatures tend to remain high from August through to September before starting to decline, said Johnson. “There’s still room to have warmer sea surface temperatures” this year.
                    Some marine heat waves this year have particularly shocked scientists for just how unprecedented they are, and the damage they are causing. Ocean heat can lead to the mass bleaching of coral reefs, as well as the death of other marine life and increased sea level rise.
                    In the Florida Keys, a marine heat wave has pushed ocean temperatures to record-breaking, “hot tub” levels, leaving multiple coral reefs now completely bleached or dead.
                    A “totally unprecedented” heat wave in the North Atlantic off the coasts of the UK and Ireland in June – defined as “extreme” by NOAA – saw temperatures up to 5 degrees Celsius (9 Fahrenheit) hotter than usual, sparking concerns about the impacts on marine life.
                    Samantha Burgess, the deputy director of Copernicus, said the heat in the North Atlantic was astonishing.
                    “We’ve never seen that kind of extreme marine heat wave for that time of year … to see them in the open ocean, to see them in spring – that’s very surprising,” .
                    Warmer ocean water also has a climate impact. Oceans play a vital role as a buffer against the climate crisis by absorbing planet-heating pollution. Warmer water does this less effectively, meaning more carbon is left in the atmosphere, fueling global warming.
                    Some scientists are concerned that the ocean temperature records set this year could mark the start of an alarming trend for ocean heat.
                    “We are continuing to put greenhouse gases in the atmosphere,” Johnson said. “And so, in the long term, sea surface temperatures are just going to continue to increase until we as a society decide to to cut our use of fossil fuels very substantially.”
                      • 37383
                      #850
                      "ON RECORD"
                      Do you know how long accurate temperature records have been kept? Most likely not mush more than 100 years. Prior to the start of commercial aviation (passenger flights) There was no need for accurate weather information.
                      FYI-The first successful weather satellite, TIROS-1, was launched April 1, 1960.
                        • 29957
                        #851
                        "ON RECORD"
                        Mush more isn't that the mountain in Utah
                          • 16330
                          #852
                          "ON RECORD"
                          Government researchers have been tracking heat waves for more than 100 years. According to data from the U.S. Climate Change Science Program, which is made available by the Environmental Protection Agency, the annual heat wave index for the contiguous 48 states was substantially higher in the 1930s than at any point in recent years. In some years in the 1930s, it was four times greater or even more.
                          Additionally, the National Oceanic and Atmospheric Administration (NOAA) has a large database of daily temperatures that goes back to 1948. NOAA used 1,066 weather stations located across the United States to collect this data.
                          According to NOAA, huge swaths of the United States have experienced a significant decrease in abnormally hot days recorded since 1948, especially in the Midwest and northern and eastern Texas.
                            • 29957
                            #853
                            Although it’s true that some parts of the United States have seen the number of hotter-than-usual days increase over the past 70 years — including in California and the New York metropolitan area, both of which happen to be areas where a large number of media outlets are located — most weather stations have shown no meaningful changes or even declines.
                            Wow isn't this the same Government that said it's climate change causing raise in temperature.
                            Asking for a friend
                            Don't worry Republicans have a plan do Nothing
                            It's fake heat made-up by the leftist media
                              Are you sure about that?
                                • 37383
                                #855
                                Very interesting considering the fact that until 2002 the U.S.Climate Change Science Program did not exist under that name. It previously was name the US Global Change Research Program which was created by the Global Change Research of 1990.
                                The EPA was not created until 1970.
