database error
  • axyun
    • Aug 2007
    • 1323
    database error
    also notice when I go to my profile and click on my activity that there is activity there that i had no part in. Also there are last 3 activity posts under my activity by
    another member which were from 3 days ago when I believe the database error issue started. Frank
  • monarke4
    • Oct 2018
    • 185
    Re: database error
    Maybe you should change the password you use to login to copytechnet, just to be sure.
    It should be unique, alpha numeric containing both upper and lower case letters. It should also not be the same as any other password you use elsewhere.
      • 37521
      Re: database error
      If you notice om the "My Activity" portion of your profile you can select All, your login name, Friends, Subscriptions and Photos. Under All you are going to see everyone who has replied to ant thread that you have replied to, ever.
