Service tips ,tricks and ideas
  • Geo
    • 662
    Greetings
    I was thinking it would be a good idea and helpful for all , to have one place to post any and all tips , tricks or ideas that worked , regardless of make or application. This would include hardware , software, web sights etc. For example , using manufactures "a" rollers in manufactures 'b" copier, or using software (___ ) to (____ ) .
    I know many of these may have been posted but they are scattered throughout posts and brands and not always easy to find.
    So what do you folks think and or suggestions.
    Thanks Much
    Geo
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Service tips ,tricks and ideas
    There's been posts like it but always seem to get sidetracked. They're fun to read tho
    • allan
      RTFM!!
      • 5459
      Anybody using paraffin on these machines?
      Whatever
      • NeoMatrix
        Senior Tech.
        • 3514
        Re. Tricks of the Trade new forum.
        There are a couple of forums relating to "Tricks of the Trade" on CTN.
        Google:
        "site:wwww.copytechnet.com trade tricks"
        Below is a couple of forums I can recall...
        hhttp://www.copytechnet.com/forums/other-copier-brands/111187-trade-tricks-2016-a.html
        Trade Tricks 2016
        hhttp://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/45201-ricoh-tricks-trade.html#post192749
        HTH
          • 22960
          You mean paraffin lamp oil? It's the closest thing to the magical Dispersant of old. Wondrous at removing adhesives, and not damaging drum or transfer belt coatings. =^..^=
          • BLADE
            former propeller tester
            • 478
            wear slip on shoes and save time getting to work
            • allan
              RTFM!!
              • 5459
              Forgot its referred to as kerosene over there. Yes that stuff.
              I carry a bottle of that stuff with me since i got introduced to it for cleaning.
              Works a treat on the high volume machine covers the inner ones to remove semi-fused toner.
              Was wondering were this stuff should not go. But so far the only thing it seem i should not do is drink it.
              Whatever
              • NeoMatrix
                Senior Tech.
                • 3514
                I've heard of a people taking a tablespoon of Kerosene prior to the colds and flu season.
                I wouldn't recommend orally consuming the unknown chemicals and heavy metals in the Kerosene.
                • allan
                  RTFM!!
                  • 5459
                  Nope not drinking that that is what rum is for. Imagine how nice the machines would smell..
                  Turpentine oil of pine trees can be used to get rid of parasites.
                  Like half a teaspoon would make you feel it in your respiratory system and you mind goes slightly wonky for a day crosses the blood brain barrier to do its job.
                  Normally taken with sugar cubes as "bait".
                  Whatever
                  • allan
                    RTFM!!
                    • 5459
                    Use your car battery to super magnetize you screwdrivers.
                    Then they will get stuck to the metal sheeting on the printers.
                    It will actually hang upsides down from metal shelves!
                    More like a prank then a trick i guess.
                    If you need to get to a screw deep inside the machine where there is a lot of metal...
                    Whatever
                      RainEx of platen and scan glass
                      RainEx Anti Fog on mirrors
                      NuFinish car polish on PCR's
                      epoxy on NON ABS plastic
                      tri-flow oil on bushings/gears
                      I'm sure my ol' brain will come up with others ... tomorrow ;-)
