useless is useless, hot damn. /rant!
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    lady: we have lines on copy
    me: do you have lines if you print from kom-pew-ter
    Lady: no lines
    me: the glass may be dirty then, could you take a look
    lady: oh there's no glass, we use the top portion. (starting to hit my head on the desk)
    me: there are two piece of glass, one on the right, one on the left/smaller could be dirty(ALWAYS IS).
    lady: *lots of noise coming through the phone, pots and pans and things...wtf.
    lady: oh we will call you when we need you, we have nothing to copy at the moment.
    me: quietly exploding...
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHH HHHHHHHHH
    Idling colour developers are not healthy developers.
  • qbert69
    • Mar 2013
    • 1152
    Re: useless is useless, hot damn. /rant!
    Lady: no lines
    DAMN WITE-OUT!!![emoji2959]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • tsbservice
      Field tech
      • 7975
      • gneebore
        • Feb 2010
        • 555
        Lady: no lines
        Ugh had to be reminded of a weird older problem with some of the later analog and earlier digital copiers, the infamous corona cleaner rod. Had a customer that was over fifty miles away and insisted no matter what if there were lines we had to come and fix it. Problem was these particular models had the handy little rod, in the main charge corona assembly, that the operator pulled back and forth and cleaned the corona wire which sometimes got dusty and added a weird charge pattern. The best part was each operators manual actually had instructions on how to use the cleaning rod when there were lines on the copies right next to the pages where they were shown how to change the toner. And of course when we installed the machines we taught the users how to use the cleaner and when. Plus i actually made a small notice of what to try for lines on the copies before calling for service and put that on the front cover. It was a simple operation--- open front cover and pull the little black or red knob out and push it back in. And close the cover and make copies. The worst part was this particular customer was a per-call charge customer with mileage and travel time charges. Yes they always wanted a full hour service when i got there so I ended up using the vacuum and cleaned covers and feed rollers and handed them a bill for two hours. Finally they went with another brand when their machine went on the list of machines no longer supported because it was over five years since the machine models were made.
        Of course we also had the same problems with ink and white out in the slit glass all over the place. Even got to the point where some customers would ask me why I didn't tell them to do that before I came out . Problem was that ones that asked that were not the ones that placed the service call and insisted we had tof fix the blasted copier
