Whats your favourite cleaning chemical
  • Morlock49
    • Mar 2009
    • 166
    As we are doing favourites, I might as well start one on substance abuse.
    My 2 favourite chemicals were Fedron and Ambersil cover cleaner (foaming only)
    I did carry around MEK for a while but it kept melting the plastic bottles lol
    Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
  • Shadow1
    • Sep 2008
    • 1642
    Fedron was only good for the customers you didn't really like that well - I remember a tech telling me about a customer that chewed his a$$ for no reason and he left pieces of his used fedron rags in every trashcan (and a few closets and desk drawers when noone was looking) he could find. I knew the customer (major jerk) and actually felt sorry for him. Sorta. OK, not really - he was a world class jackass and deserved it, but I would have felt sorry for anybody else.
    Trichlorethane and Trichloretholene were great to clean fuser guides, and didn't melt the bottle (as bad) as MEK
    We used to use Great Glass cleaner from CCP industies, until Ricoh made us get all our supplies from ISS. Now our glass cleaner is 50% Alcohol and 50% Amonia - catch a good nose full and it will knock you over.
    73 DE W5SSJ
    • Dark Helmet
      • May 2009
      • 858
      General stuff, glass, mirrors, i go into the paint isle and pickup some methal hydrate.
      Rollers i use Sel-sol. Love that stuff, it does not smell bad, works well and it does not eat plastic. It does stain things red though if your not careful.
      I used to carry Rubber Rejuv but it was giving me head aches but im going to have to start carrying it again. Nothing gets that baked on toner shit off like that stuff. I do have a beef with guys who are to lazy to remove the roller from the plastic frame when cleaning with it though. Gotta love it when the shit melts the plastic around making burs and ridge and causing document feeder jams.....
      My case cleaner is called A-707. Holy shit does that stuff work, I took a copier out of a welding shop, took the covers off, sprayed em down and the dirt looks like it was melting off. Take a scrub brush give it a quick scrub and then rinse. Looks like new. I used to go around a machine in circles spraying it down. As the dirt is sliding down the case to the floor ill start hacking away and can't breath. Must have anomonia in it
      I used to use liquid hand soap. It worked ok on new rollers. Didn't work that good on old dried up rollers though.
      • edwin3268
        • Sep 2009
        • 22
        I still find that Fedron is great in small amounts to clean that baked on toner off pressure rollers....also, ever try PFE?? Part # A3104AB. cleans label glue,markers, dirt,grease and great on rubber rollers too! Smells like citrus(orange) and is a great alternative to Fedron(which is getting harder to find with all the EPA laws.) Comes in a non areosol can and is water rinseable.
        • Jules Winfield
          • Jul 2009
          • 821
          Brillianize (anti-static glass cleaner). Also works pretty good on sticky plastic paper guides and old-school rubber doc feeder belts. Makes everything nice and slick.
          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
          • ToshibaTech
            • Apr 2007
            • 580
            I carry Windex mixed with a little rain-x (add some blue washer fluid in winter) and a bottle of water mixed with a little soap. That's all the office provides so that's all I use. I was going to buy some alcohol but I'm too cheap and what I have keeps working so...
            I will not give you service manuals or firmware.
            • DUKEY
              • Sep 2008
              • 56
              I live by De-Ink!!! can't use on everything as will take lettering off of covers! but as for toner build-up and feed rollers..it's the best!! and i've been using it for twenty years atleast.. and i use glass plus for mirrors and glass and covers!! if there's a mark de-ink dosen't remove I try softscrub!! O and triflow works great in brass bushings!! after cleaning with...guess what? de-ink lol..hope my opinion helps ...remember my opinion i'm not here to debate anyone so don't try!! thanks gl
              • TheOwl
                • Nov 2008
                • 1732
                I use anything I can drink as well so I don't have to deal with customers!!! hahahahaha
                Isopropynol or Litho (can't remember the full name for litho but it is basically a blanket cleaner for presses).
                • JVergin
                  Service Tech / IT Rep
                  • 216
                  ------ IN OFFICE -------
                  T-960 (Don't really use it anymore but we have it. A very powerful orange cleaner)
                  ------ IN TOOLKIT -------
                  Belt Cleaner (Used to clean feed rollers and get pen marks / perm marker off of covers)
                  Windex (Glass / general cleaning)
                  Simple Green (Covers / general cleaning. Also use a small amount when cleaning riso feed tires and sep pads.)
                  Iso-pro alcohol (Generally used to clean 1 way gears, metal shafts, clutches, riso sep pads.)
                  Canned air of course (obvious uses)
                  Also carry anti-static spray for the dry months.
                  • mjarbar
                    ambersil FE10 and then good ole WD40 for rubber rollers
                    CPC glass cleaner for mirrors and the copyboard glass (also good for the car windscreen as it cleans streak free)
                    Canned air
                    Canon (Longs) foam cleaner for the panels, smells nice but just not enougth of it.
                    • mrwho
                      Major Asshole!
                      • 4299
                      WD40, Konica's Belt Cleaner, Window Cleaner and Isopropyl (spelling?) alchool.
                      When all else fails, hammer and chisel!
                      Mascan42
                      Ibid
                      • Morlock49
                        • Mar 2009
                        • 166
                        I would like to see you sniff them
                        • mrwho
                          Major Asshole!
                          • 4299
                          In fact I kinda like Isopropyl alchool - I like to, once in a while, rub my hands on it, put them over my mouth and nose and take a deep whiff.
                          I know, it's bad for me, but heck, I don't smoke, so it should balance things.
                          Mascan42
                          Ibid
                          • JustManuals
                            • Jan 2006
                            • 9838
                            Fantastic is good for cleaning yellowing plastic cases. But it tastes pretty lousy
                            • waffu22
                              • Jun 2009
                              • 95
                              Only alcohol
