links directory
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    links directory
    the links directory on the home page still denies access for me....Anyone else have this problem?????
    Mystic Crystal Revelations
  • cboucher
    • Jul 2025
    It does the same thing to me...
    • Aneurysm
      Administrator
      • Jan 2005
      • 1079
      Hmmm.... Do these links work for you, let me know.
      Link 1: http://www.copytechnet.com/forums/links/index.php
      Link 2: http://www.copytechnet.com/forums/links/
      • unisys12
        • 489
        "unisys12, you do not have permission to access this page. This could be due to one of several reasons:
        1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
        2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation."
        - That's the vbulletin message I get when the page loads for both links above.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          Hey, I get this same messsage when I try. Except for kyoceradude.
          My mission here on Earth is to help all you Dum-Dums!
          • RockETop
            Curmudgeon at large
            • Apr 2007
            • 171
            RockETop, you do not have permission to access this page. This could be due to one of several reasons:
            • Tonerbomb
              • Feb 2005
              • 2589
              NEGATIVE on those links
              • Aneurysm
                Administrator
                • Jan 2005
                • 1079
                Try it again, I found a permissions conflict that I think was causing the problem.
                Let me know
                • kyoceradude
                  The Great Gazoo
                  • Aug 2006
                  • 442
                  Let me know
                  Rodger Dodger..... We have linkage......... Thanks
                    • 23007
                    Login, again & again...
                    I have a similar problem. Randomly when replying to a thread I will have to login again. Sometimes 4 times in an hour. Irritating!
                    • Tonerbomb
                      • Feb 2005
                      • 2589
                      The links are all good now! Thanks.
                      P.S. I also have had the multiple log in problem for some time now.
                      • unisys12
                        • 489
                        If your running a firewall, check it for updates. I ran into this with Zone Alarm awhile back. Downloaded an update and everythings fine now.
                        The links work fine now. And linkage is good!!
                        sigpic
