All the new KM machines now have red grease on the gearings... I've been trying to find out what it is so I could use it on the older machine, and to shut my ...m@n@g3r up.
Plastics gears dont need lube, but they certainly need cooling agent and use some noise/vibration reduction.
so far, the only grease the matches description is the "red rubber grease", its got high temp resistance rating, and easy on the rubber. But, this is for automotive brake system application.
is there anything else that's red, and copier friendly? Or, what's the grease that you use? White lithium is no good...that one got banned.
