Thermofuse Cross-section
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Does anyone have a cross-section of a thermofuse?
    Trying to explain to someone why throwing em on the floor to "reset" them isn't a good idea.
    Cheers J.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
  • Hansoon
    • Sep 2007
    • 3401
    Re: Thermofuse Cross-section
    Thermofuse or thermoswitch?
    Here's a Thermofuse
    Hans
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Here's a Thermofuse
      [ATTACH=CONFIG]16006[/ATTACH]
      Hans
      Cheers Hans, umm perhaps I meant thermoswitch, Ricoh just calls them thermostats.
      I now have a new desktop deckground though
      • zed255
        How'd ya manage that?
        • 1024
        Jonezy,
        Sorry no graphic for you, but the issue as I see it is the bi-metal disk. Once a high enough temperature causes mechanical 'inversion' and it is subsequently 'reset' it will flip to the inverted state more readily during future use. Call it fatigue, loss of pre-conditioning or whatever. The disk when tripped simply push the switch contacts apart. Also, these switches are not environmentally sealed and arcing is more likely following a reset due to contact contamination.
          • 23010
          This came from the SENSASYS website. It's not a copier thermal switch, but it does illustrate the principles involved. I hope it helps. =^..^=
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            Cheers all, much appreciated.
            • DAG COPIERS & COMPUTERS
              • Oct 2010
              • 860
              From the above diagrams it should be clear that the two components are two different things. What unites them is the variable THERMO, the heat which alters their state of existence. The thermofuse melts once and can only be replaced with another one. The thermostat or thermo/switch can break and/or remake contact depending on the temperature. But frankly speaking even me I don't understand the principle under which ''hitting'' the thermoswitch on the hard floor causes this contact to remake, although I have done it many times in the field & sometimes it does work. Another alternative is to keep it in a freezer overnight- this one can be explained!
              • Shadow1
                • Sep 2008
                • 1642
                I reset them all the time with no problem. The only exception is when the machine got WAY too hot before it shut down - don't know why, but it melted the pressure roller and a bunch of other stuff - I suspect there was something wrong with the thermostat to begin with. There were lots of them back in the day that had a reset button built in, but then the mfgr realized he could sell more if they were not resettable.
                73 DE W5SSJ
                • DWise
                  • 895
                  We have thrown our fair share of them as well... Seem to work nicely for us
                  Do for one what you wished you could do for everyone. - Andy Stanley
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    In the highly unlikely even that the worst should happen, and the connection NOT get broken when it should, I don't think I would want to be the tech responsible for that fix.
                    Some years back, we had a tech replace the 91 degree scanner lamp thermal fuse with a 192 degree one (from the fuser) on a Canon NP400 to get the customer running.
                    Whatever circuit it was that controlled the scan lamp stuck "on" after-hours that night.
                    The following morning, the customer was greeted by a blob of molten plastic parts, including the bulk of the doc feeder.
                    We had an emergency service meeting the following morning getting warned to NEVER EVER do that.
                    (No, the tech did not get fired, as he had a very good relationship with the customer, but almost anyone else probably would have.)
                    • Shadow1
                      • Sep 2008
                      • 1642
                      The very few I've had problems with after a reset have tripped out early - replacing one with more than double the temp rating is definitely not smart
                      73 DE W5SSJ
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        :: Electrically Conductive Plastic Thermostat Housing ::
                        I'm waggering that not many people have see insulating plastic turn to conductive plastic over time ?
                        I had a call to a Ricoh machine that was tripping the earth leakage system(RCD) in the building.
                        I tracked the offening problem down to the fuser unit and set about finding out why.
                        I finally found that the insulating plastic housing on the thermostats had become electrically conductive
                        over time. This machine is an old machine and doesn't get used very much. But the machine is stand-bye operational 24/7.
                        If you believe this is not possible then have a look at the image I have attached with this post.
                        You can clearly see 1.444 Mega-ohm resistance displayed on the test-point multimeter.
                        The thermostat case is sitting on a dry sheet of paper. The multi-meter probes are inside the screw sockets. No toner or developer can get inside the screw holes.
                        When the plastic thermostat house is placed back in the machine both thermostat cases read a parallel resistance of around 500 Kilo-Ohms and this appears to get less as they get hotter. The drop in resistance is enough to randomly trip the RCD electrical point in the building.
                        I fixed the problem by replacing the entire fuser unit.
                          • 23010
                          Neo: That is really interesting! Transfer bushings often use intentionally conductive plastic.
                          Years back we had a Mita DC-142 at a fire department. I was there to rebuild the fuser and was very satisfied to see that it had been two years since it had had service last, for a fuser code. While rebuilding the fuser I paid special attention to no-blow thermal fuse (paper clip). We dodged a bullet there! If the building had burned down I'm sure that the fire investigator would have found that special fuse. =^..^=
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            They were different lengths for a very definite reason.
                            • Lagonda
                              • Aug 2008
                              • 1649
                              You guys reset thermoswitches!!!! Dont you realise what a can of Health and Safety worms your opening by reusing a one shot safety device? not to ignore the insurance implications if something did go wrong either.
                              Our techs are under strict instructions not to tamper with safety systems. If a customers machine is down, tough, its down until the correct part can be obtained to repair it. If the customers complain you just say the magic words "Workplace Health and Safety" that usually shuts them up.
