BEST TONER USAGE
  • igi
    • 1507
    [Funny] BEST TONER USAGE
    hi all
    i am sure you got customers that use toner
    in some funny ways too
  • habik
    • 2013
    Re: BEST TONER USAGE
    OK time to challenge that.. I think I know what to do with a Waste toner box from a colour machine
    Lets bring the rainbow on ...
    Now Who's car gets the treatment
    Firmwares HERE
    • vamoursly
      • Sep 2011
      • 273
      Nice hot shower will sort that out
      V
      • igi
        • 1507
        V
        first she got a blow job with vacum cleaner
        then i got my cleaning brush and tikled her all over and
        i better stop now
        • TonerMunkeh
          Professional Moron
          • 3865
          This customer tried to use toner as an alternative to carpet. A few more bottles may do the entire floor? (Repost I know, but it is a corking photo)
          Hit it.
          • igi
            • 1507
            [ATTACH=CONFIG]20453[/ATTACH]
            nice one
            • vamoursly
              • Sep 2011
              • 273
              How was that managed?
              V
              • igi
                • 1507
                V
                very carefully of course
                imagine the mess if it was not
                • mikadonovan
                  • May 2008
                  • 2931
                  Looks like some dickhead pulled the toner bottle out with the cap still in the supply unit and made a little mess. Then, in a fit of idiotic rage uncorked another toner bottle or two and spread it around to show that damn copier tech who's boss. Sometime I wonder how I keep a smile on my face after crap like that.
                  NEVER ASSUME ANYTHING
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Could you actually imagine being the tech that got THAT call?
                    Hit it.
                    • RRodgers
                      • Jun 2009
                      • 1947
                      Did they try to get you too clean it?
                      • Iowatech
                        Not a service manager
                        • 3930
                        Actually, yes. A while back, I got a call for a toner spill, and when I got to the place I saw something similar to that picture, except there was toner footpaths leading out of that room (although I imagine that was the case for that photo as well). It took well over an hour to clean that up and I had to empty my vacuum's filter three times in the process, and then I had to take a shower and do laundry when I got home. Blegh.
                        • RRodgers
                          • Jun 2009
                          • 1947
                          Unless you did it or the machine did it, it's not your problem. Did you charge?
                            • 23009
                            I can imagine it ... because I was just such a tech.
                            It was a Mita DC-2585 with the "brick" shaped toner cartridge. These cartridges had a little magnet hidden in the edge of the plastic to actuate a reed switch, to tell the machine that it had a cartridge. If someone were to install a cartridge backwards, no magnet over the reed switch ... means "Add Toner" remains, and two 5mmx5mm squares of plastic break off, chew up the foam roller, and drop into the developing unit seizing the developing unit.
                            Well maybe it just needs another cartridge ...
                            After the fourth cartridge, the toner is pouring out of the cooling vents into the bypass tray. I think the manager realized at this point that maybe something was wrong. This was a retail store, so he went out to the electronics dept and got a shop vac.
                            By the time I arrived the manager had left the building. The employee cautiously opened the door and stepped back. The entire office was a nice even shade of gray. The floor, walls, ceiling, copier, furniture ... everything. I moved a letter sized piece of paper on the desk to reveal a clean rectangle 8.5 x 11.
                            Two vacuum filters and 4 hours later there was a clean area 60" x 60" x 60" which included the copier, and a path 24" wide from the door. 18 plastic corners retrieved, foam roller and developer changed.
                            The employee asked me what I was going to do about the rest of the room. =^..^=
