Annoying stickers
  • Jamesu
    • Mar 2012
    • 101
    Annoying stickers
    Does anyone else refurbish machines and find getting the stickers from the past company a ballache to remove?
    I've always used CIF and a lot of elbow grease... But earlier i decided to use the air in a can, but turn it upside down so the liquid comes out instead (The freezing cold gas)
    The sticker came off within 5 wipes with a cloth!
    What do other people use?
    Have you tried turning it off and on? No...Oh, it works now!
  • skynetto
    • Sep 2012
    • 257
    Re: Annoying stickers
    Hot air gun. Careful cause it can burn the plastic.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I collect my competitors stickers. I have them on the back of my notebook. WD-40 will remove the sticky residue.
      • Hansoon
        • Sep 2007
        • 3402
        Hot air gun + white gas or WD-40
        Hans
        • Hansoon
          • Sep 2007
          • 3402
          Not many competitors obviously...
          Hans
          • mikadonovan
            • May 2008
            • 2931
            A product called D-ink. Soak the sticker for a couple minutes and it comes right off. An absolute necessity if you work on ink duplicators like a Risograph.
            NEVER ASSUME ANYTHING
              • 23010
              Contractor De-Solv-It:
              ... but not (5) wipes. It takes a whole lot of scrubbing. Perfectly clean though ... maybe too clean. The plastic is always a little lighter where the tag was.
              On the transparent tags often you can see a silhouette of the text. =^..^=
              • MR Bill
                • 532
                The hot air gun works great to remove the sticker. Then I use some dispersant from the old liquid machines like the Savin 770. Still have some of the stuff. Works great on the glue.
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  Hans
                  5 local. Was in an elevator with a tech from 1 of them and he kept looking at my notebook. When he got off, I noticed I had about 4 of his stickers on there.
                  • copiman
                    • Sep 2011
                    • 861
                    Well Mr. Bill, you have shown your age. Guess I'm showing my age by posting this. I worked on those Savins back in the day as well. I used dispersant to start fires with on campouts or bonfire parties.
                    Anyway, I use a cleaner called "Awsome". you can get it at Dollar General for a couple of bucks. Its concentrated, but I dilute it with water. I use it to clean rollers, covers, and just about everything. If that doesn't work on the sticker issue, I use Goofoff. Very, very small amount. Another thing I use is majic eraser. Cheap to. We deal with alot of off lease equipment, and the eraser works good on covers.
                    • coolbeer
                      • Jul 2011
                      • 100
                      Cigarette lighter fluid works ok, if not you can allways sniff it and the problems seems to go awayyyyyyyyyyyyyy
                      • nos
                        • Nov 2008
                        • 78
                        Agree 100% with awesome. That stuff is great, i have never seen anything that takes off built up toner like it does and best yet its only a buck. Its kinda funny though when a customer asks what you are using that is working so well, they expect you to say its some super concentrated expensive copier cleaner, but when you tell them its a dollar store cleaner they look at you with that your a cheapskate look. Next time im going to tell them its kryptonunobtainium that costs $600.00 an ounce, well see what kind of look i get then
                        • HenryT2
                          • 962
                          I guess I'll show my age too ! ( Savin , APECO , Copystat , Canon , Remington , Toshiba , just to name a few ... )
                          We also poured the used dispersant on FIRE ANT beds, AND LIT EM UP . Great for Yellow-Jacket nests as well ( had to wait 'til dark to do those though ).
                          "The Serenity Prayer" . . .
                          God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
                            • 23010
                            Dispersant is great for label adhesive on drums and rollers.
                            The paper stickers are the worst. The adhesive turns to brown cement. Just keep soaking it. It does loosen up.
                            • Tonerbomb
                              AutoMajical Resolutionist
                              • Feb 2005
                              • 2589
                              Got 3 quarts of dispersant in the garage!!!
                              Mystic Crystal Revelations
