I almost posted this as a problem but had a feeling that, well you will see how a case of "tunnel vision" got the best of me.
The call was for a Bizhub 250 making a "beeping noise". I thought it would be a stupid call
When I went, the person who called was not in. I tested the machine, found no problem, so I turned off the volume on the speaker. Problem solved.
Two days later, the call back, "Still beeping"
When I go, the caller is there. The machine is in a secure location with a vault door.When it opens, the alarm makes a long high pitched beep. The caller says the copier makes the same noise. I make copies and after a few, a high pitched beep comes from the copier. It is not constant, but there. I unplugg the speaker, just in case and the noise is still there. Must be something rotating and rubbing. I come back and put in a new drum, because it was due, and swap the fuser. Beep is still there.
The beep is the same as the door alarm. The Commander kept getting up for weeks before they figured it was my copier, to check the door.
The beep has no pattern. Comes and goes. I notice it making the beep when turning it on, with nothing moving.
It has to be the laser. It spins, Must be going out.
I go back and change the laser. Beep is still there.
I call tech support. They suggest I change the laser.
Service manager says it is the fans. I change the fans. Machine still beeps.
At this point, I was ready to post it and ask you folks for help, but I felt I had not covered everything.
The high pitch beep seems to come from everywhere. I almost had the machine picked up and taken to the shop, but held off.
Power Supply? Maybe a capacitor is getting ready to pop. I change it, it still beeps.
I give up. After a couple more days, I go back and stare at it. I sit and look at it for while. I watch as people make copies and it beeps. Then Something catches my eye. A light in the corner of my eye. Machine beeps, I see red. Every time I see red I hear a beep.
The source??? The surge suppressor they plugged the machine into. It was overloading and screaming for help. It was on the other side of the cubicle partition beside the copier.
If I would have taken the machine to the shop, I would have unplugged from the rear of the machine and the beep would have been gone, and I would have lost it.
Well there is my "Why I am a dumb ass" story for your entertainment. I feel that confessing things like that helps keep you humble.
