Ultra Technology
  • BLADE
    former propeller tester
    • 478
    #16
    Re: Ultra Technology
    saw a news item yesterday about a big long thingy, maybe in Europe, (cant quite recall the name...Hedron excellerator??) whats the go with that
      • 14813
      #17
      The "Large Hedron Collider". It is a device used to make subatomic particles bash into each other at high rates of speed to see what is produced by the collision. Scientists hope to be able to prove or disprove certian theories about how the subatomic world works.
      • DavePo
        • Jul 2008
        • 305
        #18
        Originally posted by ZOOTECH
        Dam, you are deep - are you from this planet?
        Naw he's Dr.Sheldon Cooper in real life.
        • NeoMatrix
          Senior Tech.
          • 3513
          #19
          Nah. Some people from Asia use to email me sometimes with Dr as my name prefixed but I politely declined the offer of Doctor. I'm still very much learning like every one else.... No clouds up here for me, only mud around my boots. I prefer the ground level;I hear it gets cold and lonely up on them there mountain tops.
          BTW. The big bang theory is a crock. Nobody asks where did all the matter come from in the first place so as to create a big bang ? It's a bit like in the early ages : everyone thought the world was held up by elephants. If someone only had the sense to ask "What are the elephants standing on" the whole theory would have been dismissed. Same as the flat earth: How come all the oceans remain full of water. If the earth was flat why aren't the oceans empty?
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            #20
            So where does the Delorean with the flux capacitor come in??????????????????????
            Mystic Crystal Revelations
            • NeoMatrix
              Senior Tech.
              • 3513
              #21
              Haha I thought you would never ask.
              Which version do you want ? There are two types of hypersonic aircraft.
              The first type stream cathode rays through the outer metal skin of the craft and decompose the air molecules, which produces a tremendous vacuum above the craft. Atmospheric pressure then pushes on the bottom of the craft and moves the entire craft at tremondous speed up to 40,000km/h. At sea level atmospheric pressure is 1.033kg/cm2. A quick calculation: a 1meter round flat disc has the lifting force of around 8,000 kgm. Obviously these craft are terrestial only.
              The other version of craft use a counter rotating magnetic feild to produce a vortex field of ultra rays. These ultra rays govern the primary carrier feild in all atoms that are tune to the present time pulse wave feild of planet earth. On other planets the time pulsed ultra wave feild is slighty out of phase with the same feild of planet earth. You would describe this other field as being invisible ,but in reality it is just phase shifted with out present time frame. To generate an ultra feild you send pulses between magentic fields and adjust the distance between the plates to vary the magnetic/ultra ray
              signature you want. I won't go into other methods like using element 115 as a resonance signature up a wave guide. The speed of these ultra craft is mind boggling. Have heard information of these type of craft reaching Moons of Jupiter in minutes.
              • ZOOTECH
                Senior member of CRS
                • 3375
                #22
                WTF - where are you from? I wish I could tell you who our leader is, but I have no idea who(m) that might be!
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  #23
                  In the words of Ja Ja Binks Mesa from plannet earthsa.
                  More specifically I'm from A Number ,street,Suburb ,Rockhampton, Queensland, Australia, Southern Hemisphere Planet Earth , Terran Solar system, Milky Way Galaxy ,Light Stream Universe. Well actually a little to the left of center from there...
                  And yes the answer to Deep thoughts reply in Hitch hikers guide to the galaxy was a very coincidental 42. Which happens to be the truth. 42 is the angle in degrees a wave starts to mirror itself as it reflects to becoming a pressure point to bring about deform space into matter or physical substance. This is just pure coincidence....
                  Yes I believe according to our media your USA congress has left the building. Someone should post a letter on the White house door. "Could the last person out please turn off the lights." Seeing how the USA won't sign Kyoto Accord I believe they better save power where they can... Pun intended...
                  A little light hearted humour I try not to take things to serious, its bad for the arteries...
