Ultra Technology
  • NeoMatrix
    Senior Tech.
    • 3513
    Ultra Technology
    Hi all .
    I haven't post on copytechnet for a few months. I've been doing a few odd jobs around the place.
    With petrol prices going ridiculous around here I've been working on some different technology streams,like alternative energy and delving into forms of EMF propulsion. Has anybody else found anything interesting in these areas.
    With all the Tech heads on this forum I thought I might unearth a gemstone or two...
    Sorry to those if they find this thread offtopic....
    Neo...
    • 23009
    Re: Ultra Technology
    This is Rants and Raves, Neo. There is no such thing as off-topic.
    My current employer seems to have narrowed my responsibilities rather than broadened them.
    Tell us about this EMF propulsion (electro-motive force?).
    • NeoMatrix
      Senior Tech.
      • 3513
      b
      My current employer seems to have narrowed my responsibilities rather than broadedened them.
      G'day Blackcat...
      Your current avartar cat looks like shes gone through the rinse cycle a few times..
      I've done the same thing. My previous employer start to limit my opportunities as well.
      Re : EMF Mainly just theory at this stage. In a nut shell attempting to send a pulse train into the water molecule to give it an isotropic fluxuation. The energy that comes out pushes against the atmosphere producing a propulsion force. Mostly just theory...
      I hope all has been well for you in anycase...
      Neo
        • 23009
        b
        G'day Blackcat...
        Your current avatar cat looks like shes gone through the rinse cycle a few times..
        I hope all has been well for you in any case...
        Neo
        That describes it pretty well Neo. What doesn't kill us makes us stronger.
        I'm experiencing more frequent periods of lucidity. The additional sleep helps a lot.
        Are you still working on copiers off and on, or switched over. Details please. =^..^=
        • NeoMatrix
          Senior Tech.
          • 3513
          Yes Blackcat.
          I haven't worked on any business machines for a few months. I've been working on technical drawings which I completed a couple of months ago. The drawings are in the building stage of construction. After that I hope to get back into machine servicing again within the next couple of months. The masochist that I am, I do miss working on machines along with some of my better customers... :
          Nose to the grind stone and soldier on.... :
          • BLADE
            former propeller tester
            • 478
            b
            G'day Blackcat...
            Neo
            sounds like hydrogen bomb theory, good luck with the neighbours
            • NeoMatrix
              Senior Tech.
              • 3513
              Yes its a bit like a hydrogen bomb theory. You just have to know where the water molecules energy matrix converts isotropic energy and reflects anisotropic wave. When you get a dual wave travelling out from a known flucts point you can transmitt energy over distance to the same point continuously. And therefore push away any molecule at the distant point producing propulsion or energy transferal.
              • Jules Winfield
                • Jul 2009
                • 821
                It kinda sounds like the episode of South Park where Randy cheats at Stan's pinewood derby race and sort of discovers warp speed.
                But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  I rarely watch the idiot box (TV) I don't known South Park.
                  It's a bit like what Nicola Tesla was doing . What people didn't know is that there is a fundmental frequency matrix which sets the primary carrier freqency in all atoms. Tesla new this and could transmit energy/modulation over the carrier an produce amazing results. Just think if you new the methods of tesla you would posess Ultra Technology. You would be able to tranmit energy to a distance. Set up a known force feild around an object. Down a ICBM. Knock out all forms of communication and set up distorted telepathy communication directly into the minds of your enemy, or transmit battle orders to the same water molecules in auditory cortext mind of your own secret army. You could create hyper speed flight aircraft with speeds approaching 250,000 mph. Plus many more known Technologies like how to cure cancer. The cancer cause is based on the hydrogen molecule or H4 heavy water. If you transmit the correct matrix signature into the body water of the patient you can strip an electron off the cancer cells and cause a recession. Injecting people with radiation is absolutely horrendous. Second form of cancer is viral or parasites. A change in diet , namely to much red meat ,and cleaning program can cause a recession. Many marvelous new metals composits and construction techniques. The Technology gets better and better if people would only put their arrogance and ignorance to one side.
                  • Iowatech
                    Not a service manager
                    • 3930
                    Kind of sounds a little bit like the the study of harmonics in communications. You want an antenna that will pick up or broadcast a certain frequency of radio transmission, the most effective length of the antenna is found by dividing the desired frequency by the speed of light. Sometimes that isn't practical, so you use harmonics of the frequency to find a smaller or larger size. Usually by dividing or multiplying the desired frequency by some power of two.
                    Sorry if that's not even close.
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      There is a termed used in radio transceivers call hetrodyne or superhetrodyne. It's when you mix two carrier waves together and cancel/retreive the modulation signal off the carrier wave. You use a circuit call a phase lock loop ( PLL) It generally come in a single intergrated chip IC package in all moden receivers. When the two carrier wave beat the same frequency you get four total frequencies : plus ,minus the modulation of the carrier, the carrier ,and the sum. I won't get into the mixer Intermediate Frequency (IF) stages of the circuits, but as an example some of these circuits have fixed IF frequencies like 455khz or 450mhz which is why it's illegal to transmit RF in any of these frequencies. If you did it would interfere with the mixer stage and you could get people to believe thier TV or Broadcast radio is posessed by god or demons, get the idea. It's even easier to do this with some newer digital devices.
                      You are getting the idea though. You just have to place it all together in a mathematical matrix that show where and how the harmonics interact with a primenumber carrier wave set to produce marvelous wave patterns like a frozen snow flake. When done in a mathematical matrix you quickly learn how nature stores an uses energy in the most marvelous way nothing is wasted. You would come to understand that the entire universe is a multiverse with holographic matrix within holographic matrix or worlds within worlds. You would begin to understand how dimensions and differnt time frames come about.
                      • Kidaver
                        Ghoulscout
                        • Apr 2011
                        • 912
                        I tried to keep up with all this and got lost...but for some reason this came to mind...
                        Buttered cat paradox - Wikipedia, the free encyclopedia
                        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                        • fixthecopier
                          ALIEN OVERLORD
                          • 4713
                          This is a very interesting thread. I think Einstein said something like "If you can't explain something simply, you don't understand it." You are doing a good job of explaining it.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Love the buttered cat..
                            If you delve deeper into the cat paradox it actually describes two opposing forces. These could be interperted as positive negative, black light , white light or yin yan or the dual forces acting at right angles inside a vortex feild or tornado.
                            Yes that is correct there is two torus forces inside a tornado. You have an outer force travelling around the inner tornado force but travelling in the opposite direction. Both forces attract/suck matter into their scalar path. There is a null void in the center of every tornado when no force is present. Both forces inside the tornado act at right angles to their votrtex center thus producing a second vector force which gives the tornado four active forces.
                            Sorry for my spelling and grama , I'm using my Android tablet and correction is sometimes slow, so I don't bother about going back up the text to correct it.
                            • ZOOTECH
                              Senior member of CRS
                              • 3375
                              Dam, you are deep - are you from this planet?
