PC or MAC Tips and/or Hints
  • Phrag
    • Oct 2012
    • 417
    #16
    Re: PC or MAC Tips and/or Hints
    Originally posted by Debs1964
    I am so going to remember that for the next time one of my colleagues leaves their laptop on when I'm around
    Brilliant. Thanks for that idea.
      • 37571
      #17
      Originally posted by emujo
      With Windows 8, and SMB scanning. With the users permission, create a standard account to use with scanning, the default account uses a "@mailaccount.com" and is not very friendly with the SMB authentication. Emujo
      When you are first installing Win 8 you have to option to set it up using a standard account. It makes things much easier for setting things up later.
      • ZOOTECH
        Senior member of CRS
        • 3376
        #18
        This is "old school" for most, but if it helps just one, I'll be happy.
        To delete, move, or highlight a group of items: highlight the first item, scroll down to the last item and with the 'shift' held down click it - all the items between the two will now be highlighted.
        If you have an item or more that you do not want highlighted, hold the 'ctrl' button when clicking and it will not be part of that group.
        This is very helpful when getting rid of your 'Deleted Items' in Outlook.
        Holding down 'Ctrl' down and pressing 'A' will select all.
        • Phrag
          • Oct 2012
          • 417
          #19
          Here's one I found when I was forced to troubleshoot connectivity on a MAC; in the system prompt (I think it is. MAC version of cmd prompt), type 'ifconfig' for a readout similar to Window's 'ipconfig.'
          I've never messed around with or used an apple machine. I've only ever used Windows PCs.
          • nazia
            • Oct 2013
            • 14
            #20
            I need a laptop for school work, my itunes account, and I also make gifs and photo edits in my free time; I need to replace the laptop I currently have which is a dell, it's about 2 or 3 years old now. I don't have a lot of money so I really can't go looking for the best, I just need one that is practical and affordable and will hopefully last me at least through college. Thanks
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              #21
              Not sure what you are asking here but I doubt anyone really cares about laptop sales in this forum.
              I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                #22
                Just buy the latest iCrap like your fellow classmates.
                • CompyTech
                  Super Tech
                  • Feb 2011
                  • 706
                  #23
                  ::hits the space where the like button should be::
                  • Phrag
                    • Oct 2012
                    • 417
                    #24
                    Here's a nifty one.
                    If your Windows based PC takes a while to finish starting up, go to Start > All Programs and open up the 'startup' folder. Any program in that folder tends to run when you log in. Deleting it from this folder generally stops it, thus speeding up the login process.
                    I should probably state that in some circumstances it may be necessary for some programs to start up on login, depending on your companies policies, so I'll state that you do this at your own risk.
                    My startup folder is empty, so most basic programs don't start without me telling them to. Obviously, there are other programs and processes which start up, but I use 3rd party software to monitor that.
                    • TheOwl
                      • Nov 2008
                      • 1732
                      #25
                      Windows Key + Pause / Break = System Properties
                      Windows Key + D = Show Desktop
                      Ctrl + Alt + End = Ctrl + Alt + Del in an RDP session
                      Running "msconfig" will give you all the boot, services and startup options for installed software
                      Running "services.msc" will give you the services snap in
                      Ctrl + Esc = Pressing Windows Key on a keyboard without a Windows Key
                      Pressing Ctrl + Alt + Del twice in succession on XP Home Welcome Screen = Allows you to login as the administrator
                      Running "ping -a xxx.xxx.xxx.xxx" will attempt to resolve the host name of the IP address you are pinging
                      Running "ping -4 hostname" will run a ping using IPv4 only (handy for networks with IPv6)
                      There are heaps more out there and I am probably using some of them already, but it is an automatic thing I do so actually writing out all these handy little tips and tricks becomes harder... lol
                      • emujo
                        • Jun 2009
                        • 3009
                        #26
                        Found this gem recently, at a command prompt, type "CD " (cd space), press TAB and the folders/files within that directory will scroll with each tap of the tab button. When you find the directory you want press enter, then repeat the process. Makes it much easier to navigate directories without having to type the exact string to get to the file you need. Emujo
                        • TheOwl
                          • Nov 2008
                          • 1732
                          #27
                          Ctrl + Shift + ESC = Brings up the task manager
                          Ctrl + Shift + N = New Folder
                          • Iowatech
                            Not a service manager
                            • 3930
                            #28
                            I forget if I've shared this before, but running "tracert" followed by a URL in the command prompt is a way to see if a website is slow because they are having problems, or you're connection has to go through an unusually large amount of server connections to get there.
                            One of the inherent flaws in a somewhat mesh like network that is the internet. If it isn't denied by some external force, you can always get to what you are looking for, but sometimes you will take the long way around.
                            "tracert" still works in Windows 8.1, I just tried it. The command prompt can be found in system configuration there.
                              • 37571
                              #29
                              If you use the command prompt frequently, do like I did, pin it to the taskbar.
                              • TheOwl
                                • Nov 2008
                                • 1732
                                #30
                                Or simply use Windows Key + R to bring up the run box and then you type in "cmd".
                                I just don't like cluttering my task bar or desktop with shortcuts...
