PC or MAC Tips and/or Hints
Re: PC or MAC Tips and/or Hints
When you are first installing Win 8 you have to option to set it up using a standard account. It makes things much easier for setting things up later.Comment
This is "old school" for most, but if it helps just one, I'll be happy.
To delete, move, or highlight a group of items: highlight the first item, scroll down to the last item and with the 'shift' held down click it - all the items between the two will now be highlighted.
If you have an item or more that you do not want highlighted, hold the 'ctrl' button when clicking and it will not be part of that group.
This is very helpful when getting rid of your 'Deleted Items' in Outlook.
Holding down 'Ctrl' down and pressing 'A' will select all."You can't trust your eyes, if your mind is out of focus" --Comment
Here's one I found when I was forced to troubleshoot connectivity on a MAC; in the system prompt (I think it is. MAC version of cmd prompt), type 'ifconfig' for a readout similar to Window's 'ipconfig.'
I've never messed around with or used an apple machine. I've only ever used Windows PCs.Comment
I need a laptop for school work, my itunes account, and I also make gifs and photo edits in my free time; I need to replace the laptop I currently have which is a dell, it's about 2 or 3 years old now. I don't have a lot of money so I really can't go looking for the best, I just need one that is practical and affordable and will hopefully last me at least through college. ThanksComment
Not sure what you are asking here but I doubt anyone really cares about laptop sales in this forum.I have not failed. I've just found 10,000 ways that won't work. ~Thomas EdisonComment
I need a laptop for school work, my itunes account, and I also make gifs and photo edits in my free time; I need to replace the laptop I currently have which is a dell, it's about 2 or 3 years old now. I don't have a lot of money so I really can't go looking for the best, I just need one that is practical and affordable and will hopefully last me at least through college. ThanksCthulhu for president! Why settle for the lesser evil?Comment
Here's a nifty one.
If your Windows based PC takes a while to finish starting up, go to Start > All Programs and open up the 'startup' folder. Any program in that folder tends to run when you log in. Deleting it from this folder generally stops it, thus speeding up the login process.
I should probably state that in some circumstances it may be necessary for some programs to start up on login, depending on your companies policies, so I'll state that you do this at your own risk.
My startup folder is empty, so most basic programs don't start without me telling them to. Obviously, there are other programs and processes which start up, but I use 3rd party software to monitor that.Comment
Windows Key + Pause / Break = System Properties
Windows Key + D = Show Desktop
Ctrl + Alt + End = Ctrl + Alt + Del in an RDP session
Running "msconfig" will give you all the boot, services and startup options for installed software
Running "services.msc" will give you the services snap in
Ctrl + Esc = Pressing Windows Key on a keyboard without a Windows Key
Pressing Ctrl + Alt + Del twice in succession on XP Home Welcome Screen = Allows you to login as the administrator
Running "ping -a xxx.xxx.xxx.xxx" will attempt to resolve the host name of the IP address you are pinging
Running "ping -4 hostname" will run a ping using IPv4 only (handy for networks with IPv6)
There are heaps more out there and I am probably using some of them already, but it is an automatic thing I do so actually writing out all these handy little tips and tricks becomes harder... lolPlease don't ask me for firmware or service manuals as refusal often offends.Comment
Found this gem recently, at a command prompt, type "CD " (cd space), press TAB and the folders/files within that directory will scroll with each tap of the tab button. When you find the directory you want press enter, then repeat the process. Makes it much easier to navigate directories without having to type the exact string to get to the file you need. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
I forget if I've shared this before, but running "tracert" followed by a URL in the command prompt is a way to see if a website is slow because they are having problems, or you're connection has to go through an unusually large amount of server connections to get there.
One of the inherent flaws in a somewhat mesh like network that is the internet. If it isn't denied by some external force, you can always get to what you are looking for, but sometimes you will take the long way around.
"tracert" still works in Windows 8.1, I just tried it. The command prompt can be found in system configuration there.Comment
Or simply use Windows Key + R to bring up the run box and then you type in "cmd".
I just don't like cluttering my task bar or desktop with shortcuts...Please don't ask me for firmware or service manuals as refusal often offends.Comment
