Must-have specialty tools and parts for a tech
  • JR2ALTA
    • Feb 2010
    • 2031
    Re: Must-have specialty tools and parts for a tech
    The must have tools are the ONLY tools in this trade. Don't carry crap you don't need.
    #1, #2 screwdrivers
    Set of precision (very small) flat blade and phillips screwdrivers.
    Spring Hook
    Hemostat
    Needle nose pliers
    Duck billed pliers
    Retainer Ring pliers
    Flashlight
    Scotch Brite
    Magnetizer
    Sandpaper
    Extra screws and e-clips
    6 inch ruler
    Oil
    Rags
    Windex, Alcohol
    Electrical Tape
    Super Glue
    Super-Secret tip of the day: Get a few rubber hoses of different diameters, cut them small, when ready bite down on them they maek perfect door cheats.
    • Phrag
      • Oct 2012
      • 417
      Originally posted by JR2ALTA
      Extra screws and e-clips Jesus Clips.
      Fixed.
      Originally posted by Akitu
      A paper clip...
      No lie there.
      What I carry around is a Standard sized Magnetic Philips head screwdriver.
      Flat Blade Screwdriver
      Needle Nose Pliers (magnetized tips)
      1 Set of precision screwdrivers
      Magentizing block.
      Those pliers that open when you squeeze them (For those BIG C clips on 601 fusers etc)
      RRR (Rubber Roller Restorer)
      Shellite (R35 - Hydrocarbon)
      Isopropyl alcohol
      Spare screws and Clips.
      Microfibre cloth.
      couple of rags.
      Lubricating oil (for hot areas)
      Drum dust stuff
      Spring Hook (Thick paper clip bent into required shape)
      I use a paper clip as a spring hook.
        • harleyrider
          • Oct 2011
          • 348
          #19
          Tylenol or some other form of pain reducer for the bad days.
          • BHRLC
            • Nov 2013
            • 77
            #20
            Oh man, you all really delivered!
            Thank you guys a million
            I would have not thought of some of these...
            Metal detector app?! serious? haha... for what, exactly?
            I'm adding small switch and hub to the network tools side of things.
            And maybe cheap wifi router.
            • nmfaxman
              • 1702
              #21
              Why waste the money on a switch and hub?
              Crossover cables work on any ethernet network and PC to device and are easy to make as long as you want.
              Regular ethernet cables only work on a network switch or router.
              I test their wi-fi with an app on my phone that shows signal strength, better channels available and surrounding wi-fi signal strength.
              I test scan to email by sending an email to my phone.
              I walk into most calls with a screwdriver, flashlight and a damp rag and go back for what I need.
              Search for drivers on the internet and save them to a file you update and reload a USB thumb drive.
              Buy or Google for all the manuals as you need them and save them.
              Download for customer and save it on your thumb drive.
              Before you know it you will have all you need without a huge investment all at once.
              The only real things you need in this career is heart and an individual pride that you made a machine run well that really shouldn't work at all.
              • rh112
                • Dec 2007
                • 51
                #22
                SuperLooper
                Got one of these sometime back
                Connect direct to normal network cable and you have a crossover cable
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  #23
                  You may want to carry a small wired router as well, as some IT admins will freak out if they see you broadcasting their network wirelessly.
                  i also highly recommend installing Wireshark on your notebook, and actually learning it (lots of free tutorials on it) You'll find that most IT departments don't have a good handle on it.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    #24
                    if you want to do packet captures ( I do at least once a week ), you will need a hub ( a switch won't work ).
                    I found a 10/100 hub on eBay a few years ago. It cost me all of $13.00.
                    • JR2ALTA
                      • Feb 2010
                      • 2031
                      #25
                      why the bleep do you capture packets once a week?
                      • Tonerbomb
                        AutoMajical Resolutionist
                        • Feb 2005
                        • 2589
                        #26
                        Some of us actually have to do IT troubleshooting to prove to the customer that it's their problem not the machine. It sucks and it happens....
                        Mystic Crystal Revelations
                        • Hansoon
                          • Sep 2007
                          • 3375
                          #27
                          Why only a hub if I may ask?
                          Hans
                          • Tonerbomb
                            • Feb 2005
                            • 2589
                            #28
                            Hans
                            A hub will broadcast all packets to all ports, a switch will filter the broadcast to a port with a certain ip. that's the difference.
                            • Hansoon
                              • Sep 2007
                              • 3375
                              #29
                              Hans
                              • JR2ALTA
                                • Feb 2010
                                • 2031
                                #30
                                if you need packet analyzing software to troubleshoot network problems...once a week.
                                you either live in 1992 or you never heard of Command Prompt
