Friday we took a call from the local VA hospital in desperat need of someone to put a belt on an HP T610 plotter. I said I would do it on Monday, knowing I would have no other calls with the base closed down for the holiday. The hospital was also closed, but they made arrangements to have the police let me in. Customer had supplied the belt. They had planed to install it until they downloaded a manual and saw what was involved.
The machine was in an office that was about 8 X 14, with other office furniture. The belt was visibly damaged. Each time I would go from one side to the other, I would have to pick it up and move it.
If you have never taken apart one of these, it will make you want to punch the guy who designed it in the mouth. With the confined office fighting me, it took 4 hours for me to get it all back together with a new belt. I booted the machine only to see a service code of 47:01, which is a starwheel motor. When I called the customer and explained this, I was told that the code is what shut the machine down and when they saw the condition of the belt, they assumed that was the problem. I explained how that would have been good info from the start, as he would have to pay for a couple more hours for me to put that in the next day with staff in the office. I could have installed it while doing the belt.
Another glaring difference between a tech and an end user... Even when they have the manual, the end user can't come to the correct conclusion about his machine.
