Dumbest thing u have seen a tech do!
  • allan
    RTFM!!
    • 5462
    Found this guy with just over a years experience. So being the junior i can ask him to do things for me from time to time like building up web units for a Konica Minolta B601. Gave him a used unit and a new 3de party "refill" to do, got it back in a box and of i went to the customer. On getting there the web is installed the wrong way round (that takes some doing), checked the installed web and there was still a little life left so after the rest of my calls getting back to the office and showed him that it was faulty and gave him another used one to copy explaining that the big roll goes on the side without the gear. This is the part i could not get over, he took the sample and rebuilt if the same way as the one he screwed up already!!!
    Whatever
    • 23009
    Re: Dumbest thing u have seen a tech do!
    The single dumbest thing? I don't think that I can narrow it down. Here's a few:
    We had a Mita DC-131 in the shop with the back off. I can't remember why it was being serviced, but I was watching the tabletop drive chain cycling back and forth. One of our senior techs comments that the bicycle chain drive is unbreakable. So he takes my screwdriver and jams it into one of the links of the chain, stalling the motor. "Now you've got something to fix" he says.
    We had a tech years ago that worked on and off at two different branches of the company. He came in asking for a Mita DC-1205 lamp cable, because the lamp wasn't lighting intermittently. About an hour later he came back, and asked for another lamp cable. "Why do you need two?" He said: "I got it installed, and tie-wrapped in place, but when I went to cut the tie wrap ... I accidentally cut the harness instead."
    This same tech thought that those lamp shading plates/shutters were an invention of the devil, specifically there to cut the back of his fingers when cleaning optics. To remedy this major injustice, he loosened the screws, and pulled back all those little shading plates, so there was lots of room to clean the reflector, lamp, and mirror. At the same time he un-adjusted the exposure evenness on every machine he touched. The really curious part, is that he could not understand how moving those plates that shade the lamp could make any difference in lightening or darkening the copy. He continued to un-adjust every single machine he touched. Some people shouldn't be technicians.
    This same tech had an oiler, and used it on every opportunity. He oiled electromagnetic clutches, greaseable spring-wrap clutches, magnetic torque limiters, leather friction clutches, fuser rollers, photointerrupters ... well, just about everything. Some people shouldn't be technicians.
    More later =^..^=
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Well now we've dated ourselves by the DC 131
      Mystic Crystal Revelations
        • 23009
        They don't sell those any more? =^..^=
        • sharptech1
          • Oct 2011
          • 163
          Just took a customer from a crappy dealer. Their major complaint on one machine was that the bypass didn't work. Customer said dealer took machine into shop for a month to repair, brought it back, and it still didn't work. I got into it and realized the entire paper feed drive unit had been taken apart. Somehow they got all the gears back into place but they put the bushings on backwards and used some kind of glue to hold them in place, which didn't hold. Then they didn't ground the unit and promptly fried about 5 wires. They used electrical tape to wrap the wires and sent the machine back still ungrounded. I could wiggle a drive gear and cause sparks which assured me the account after I showed the customer.
          • ZOOTECH
            Senior member of CRS
            • 3375
            I hope the afore mentioned tech is no longer working with you; leaving "time bombs" in machines is a no-no!
            • sharptech1
              • Oct 2011
              • 163
              I pulled that account from the competition. I couldn't believe what I saw. Been getting many complaints about them. Think they are failing.
              • Josh93
                • Jul 2014
                • 47
                Probably not the best place to admit ones self, but on one of my first service calls with a senior tech, I pulled out a drum unit from a KM upside down and filled his bag with waste toner.
                • allan
                  RTFM!!
                  • 5462
                  One tech primes the new C654 color IU's before installing and keep on replacing the transfer rollers because they are full of yellow toner from the factory even called KM to complain about it.
                  Whatever
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    When my territory tripled in size, they hired a second "tech" to help. He had never worked on copiers. He had an online degree in electronics, and that got him the job. The first training they sent him to was for Lanier color printers. This shows how smart my management is, as the contract was for Konica Minolta b&w boxes. He went to school with another real tech. Came back and found out he had smoked the machine they were training on. Lanier ask he not be sent back. Shop kept him 6 more years until the contract ended. Made my life miserable. He was one of those people who would ask a question and if the answer seemed hard, he would ask someone else. Couldn't figure out how to fix something? No problem, he would tell the customer they couldn't use that feature.
                    During that contract, the delivery guys tipped over a Di470. Bent the frame. They took it back to shop and the service manager declared it to be OK. I would then get these repeat calls on it, because the right side door would not stay shut. Finially went to the owner and had it pulled. Service manager sent it back out. The last time I worked on it my ticket read..."Works fine if you keep a large heavy desk up against the right side"
                    • CompyTech
                      Super Tech
                      • Feb 2011
                      • 706
                      A goof on me... I had spent a week working on nothing but bizhub 950s, they have drum carriages that come out on rails. I came back to the shop to work on a bh601. I pulled out the drum unit only to have it crash to the floor and send toner and developer out in a 6ft radius.
                      • allan
                        RTFM!!
                        • 5462
                        Also dropped a drum on a Ricoh MP9000 thinking that the drum cradle works like a AF2090.
                        Whatever
                        • fixthecopier
                          ALIEN OVERLORD
                          • 4713
                          If we are now confessing, I put developer for a bizhub 501 in a bizhub 600. Discovered it 3 hours later when I went to do the 501. The 600 was still running, but had a hazy background. I was distracted by a female...
                          • ZOOTECH
                            • 3375
                            My first big goof was working on a Sharp SD4085 (in the shop, thankfully) and trying to pull the DV unit out the right side. I grabbed a handle underneath the unit thinking it was the drawer release.
                            Unfortunately, that handle releases the developer tank to empty during a PM with a box and trash bag liner to catch it - without that box, the dv emptied onto the floor and right side of copier.
                            Took several hours to clean everything up, with my manger watching every step.
                            • allan
                              RTFM!!
                              • 5462
                              Screw driver slipped when i removed a SSD from BH36 and knocked off one of small component that completes the data circuit that runs to the laser. The machine would work fine but no image! Turned out that the problem was the SSD but now with a useless MFPB.
                              Whatever
