Mistakes you made when you were a ROOKIE (noob--whatever)
  • theengel
    • Nov 2011
    • 1784
    Remember all the stupid things you did when you were first starting out?
    One of the things I did, over and over again, was to treat each customer as if they were more interested in saving money than having their machine work. I would do things like clean rollers instead of replacing them--only to have to come back a few days later (or a few hours later). It took me like SIX MONTHS to learn.
    It also took me a while to figure out that cusomers want to see confidence... fake it till you make it.
  • igi
    • 1507
    Re: Mistakes you made when you were a ROOKIE (noob--whatever)
    yes I was trying to fix the copier.
    and then I realised the problem was to educate the customer.
    in the long run much more beneficial for both
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Not unplugging the machine from the mains. Only do it once....
      It didn't say that I couldn't do it in the manual.
      • Debs1964
        • Oct 2010
        • 1690
        I must be really dumb, I've caused problems more than once that way
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • buzz
          • Aug 2013
          • 288
          Put machine back together and had a problem with blank copies.
          Troubleshoot it thinking main charge corona area that i worked on, but just forgot to put an original on the glass!
          Greased scan rails, then had a black line on copies... did not know what the heck that was. Service manager went out and found my black grease cap in the 1st scanner mirror... . hence the nickname "grease cap", never heard the end of it.
          wow, i gotta lighten up on the noobs.
          another tech scraped a office girls' leg with his super long phillips screwdriver sticking out of his pocket as he was getting up from a squat position .
          another tech thought his car was stolen in an office parking garage, but was actually parked on another floor.
            • 37442
            Hell son you expect me to remember that far back.
            • Hansoon
              • Sep 2007
              • 3380
              When I was a rookie I made a very big mistake affecting my life dramatically:
              I became a copier tech.....
              Hans
              • subaro
                • Oct 2010
                • 1274
                Ouch!!. Is the fuser hot. placing finger on the fuser rollers to check if its hot. [ I still see techs do that today ].
                • bigdaddy
                  • Feb 2015
                  • 35
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Hans
                    The horror!!!
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I once sprayed WD40 on a Canon NP80 (liquid machine) to try to eliminate a squeak in the drum drive area.
                      Unfortunately it was running at the time.
                      A nice green flame shot out with a loud BANG when it hit the primary corona.
                      Scared the crap out of the highly populated office it was in. (And me, of course...)
                      • Iowatech
                        Not a service manager
                        • 3930
                        When I first started working on copiers, I stored my tool case in the trunk of the car while on the clock, and then I brought it in the house when I was done. That ended after the second time I discovered I forgot to load the tool case in the car when I arrived at my first call, which was fifty miles away in both cases. Ever since then the tool case stays on the front passenger's side floor 24/7 unless I am using it on a service call.
                        • theengel
                          • Nov 2011
                          • 1784
                          Yeah... it's like those dreams you have as a kid where you suddenly realize you forgot to put on pants before school.
                          • jonhiker
                            • 661
                            while still being trained in the field,while rebuilding a fuser, i put the wrong screw in the wrong spot...when the copier was powered on, it blew a circuit breaker in the office. no damage done.. except to my pride.
                            • ZOOTECH
                              Senior member of CRS
                              • 3375
                              It happens - get over it (as it seems you've done)!
