Does anyone here know about gas dryers?
    • 23009
    I've got a Whirlpool LGR4634EQ3 that usually lights for the first few minutes in low heat mode, then stays cold with the drum turning. If I select high temperature mode it seems to stay lit for up to 1/2 hour then goes cold. In timed dry it will also stay lit for about 1/2 hour then go cold
    I've ruled out the following items:
    igniter coil: lights up whenever power is applied
    gas coils: supplies gas during the initial part of the drying cycle
    high temperature thermostat: non-resettable
    thermal fuse: non-resettable
    plugged exhaust: ductwork is clear. Good airflow at the exhaust.
    None of these parts would be intermittent by my estimation. If they work from a cold start, they would conceivably continue to work.
    Most likely causes:
    cycling thermostat: shuts down the burner when the thermostat exceeds 160F, then resets at 90F (it's in the back, so it's somewhat inconvenient to check while live.) It's reasonably inexpensive, and high on my list of choices, so I've got it ordered.
    flame sensor: shuts down the gas if the flame doesn't light.
    timer: Somehow I don't think the timer would be intermittent though.
    Do we have anyone with dryer experience? =^..^=
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Does anyone here know about gas dryers?
    Yes BC I have some dryer experience as I was taught by Dad how to work on anything, but I did a quick Google for you :
    Whirlpool Dryer Doesn't Heat - Model LGR4634EQ3 - Repair Parts - RepairClinic.com
    http://www.partselect.com/Models/LGR4634EQ3/
    Mystic Crystal Revelations
      • 23009
      I did find the Repair Clinic website. That's how I got it apart without too much damage. =^..^=
      • Lagonda
        • Aug 2008
        • 1649
        We use a hydrogen powered gas drier and so far it hasn't given us any trouble in the last 4 billion years.
        • allan
          RTFM!!
          • 5462
          [ATTACH=CONFIG]29641[/ATTACH]
          Dont joke. I just constructed a HHO generator that work much better than expected. Some safty issuse conserns, because you can loose your facial hair and your hearing if something goes wrong. Also not easy to burn that stuff off without a bang!
          But can power a gas generator! Next move its going on my car.
          The energy crisis and power cost in ZA makes a electric dryer just to expensive to run.
          Whatever
            • 37532
            Normal operation for the dryer is to have the burner come on at the start. It should then stay on until the cycling thermostat reaches its set temperature. Without looking at a schematic I am only guessing that when the temperature drops below the low end of the cycling range, the cycling may key the gas solenoid directly or may key the timer to open the solenoid. One thing to check, when the burner shuts off, wait about 5 minutes and then open and close the dryer door and press the start button. If the burner comes back on, my guess would be the timer.
              • 23009
              We are currently using that hydrogen based dryer right now. It seems to be pretty reliable so far, just a little slower than the other variety.
              Thanks slim. I did resist the timer only because of the warning message at Repair Clinic. Essentially it said "Most of the time it's not the timer, and we'll charge you a restocking fee if you'd like us to take it back."
              I'll post back when I know something useful. :P
              • harleyrider
                • Oct 2011
                • 348
                My boy has a electric one that was doing very similar thing.I replaced the thermistor for him and it works fine. His is electric but sounds like the same problem. It was a cheap part if I remember right.
                • Tonerbomb
                  • Feb 2005
                  • 2589
                  Igniter works, Check
                  Gas valve works, check
                  Dryer comes to temp at first,check
                  fire doesn't come back on after cycling and drum cools down, check
                  I think I would look at the cycling thermostat.............
                    • 23009
                    OK, I know a little more now.
                    I installed the cycling thermostat today. The switching terminals closed to 0.1 ohms. The low temperature coil read 6990 ohms. The new part reads 0.1 ohms across the switched terminals, and 7500 ohms across the low temperature coil. Personally I think any differences in readings are insignificant/incidental. It's the temperature that it switches, then switches back that counts.
                    While I was in the back I also checked the thermal fuse (0.1 ohms), and the high temperature thermostat (38 ohms?! What?). I took my readings off the spade connectors. The terminals on the high temperature thermostat read 0.1 ohms. After a little wiggling, the spade connectors also read 0.1 ohms. There must have been some corrosion in the terminals. The change in temperature could conceivable also change the resistance in the connection. The thing I don't know, is the threshold at which the resistance across the high temperature thermostat is interpreted as open/closed.
                    Regardless, it still seems to be doing the same thing. After about 30 minutes the flame goes out. The igniter lights up about once a minute but it doesn't flame. According to Repair Clinic that points to the gas valve solenoids. Perhaps it magnetizes after so many minutes energized? So it's time for another order.
                    I guess we'll be using that hydrogen powered dryer for another week. =^..^=
                      • 37532
                      My guess would be that the heat in the faulty spade connector is raising the resistance of the loop enough to keep the gas solenoid from pulling in. More current is normally required to pull a solenoid in than to hold it in once energized.
                        • 23009
                        I think I knew that. =^..^=
                        • nmfaxman
                          • 1702
                            • 23009
                            Well I think I fixed something. The gas coils arrived today and installed in about 10 minutes (I've had some practice). It's dried 3 loads of laundry all the way through.
                            Here's the point I don't get: The gas coil is just a solenoid. A coil of copper wire around a ferrous core. Which part is intermittent? The coil either has a circuit or it doesn't. The ferrous core is the same one, not replaced, so theoretically if it was magnetized it would still be magnetized.
                            Regardless, it's fixed for $30USD. I'm happy. =^..^=
                            • Lagonda
                              • Aug 2008
                              • 1649
                              Originally posted by nmfaxman
                              I just hope the person responsible isn't a copier tech!
