Mpc 2800 add toner sign and copier is not working
  • sahara
    • Sep 2012
    • 18
    Sir
    I have a MPC 2800 it is showing add toner and replace toner.We replaced toner and the result is same.We checked with output mode and no motors are working what will be the possible soulution
  • Aneurysm
    Administrator
    • Jan 2005
    • 1094
    sahara, thanks for posting, we hope to see you back soon!
      • 37590
      Re: Mpc 2800 add toner sign and copier is not working
      This forum is for introducing yourself, not for problems. If you expect help, post your problem in the following forum:
      http://www.copytechnet.com/forums/ri...tetner-lanier/
      Actually if you check that forum you will find numerous threads on this same problem with Ricoh color machines.
