toshiba 306
  • chelsy11
    • Apr 2016
    • 7
    toshiba 306
    please help i have a problem toshiba 306 theres an error code F901 and when i turn it on and off the machine will be ready but when i start to copy i makes an error CA20
  • Aneurysm
    Administrator
    • Jan 2005
    • 1029
    chelsy11, thanks for posting, we hope to see you back soon!
    • chelsy11
      • Apr 2016
      • 7
      Re: toshiba 306
      im happy to be a member of copytechnet, i will give info as i can
      • bob marley
        • Jan 2012
        • 1339
        Re: toshiba 306
        Welcome
        This forum is only for introducing yourself to the others
        If u still need help post here http://http://www.copytechnet.com/forums/toshiba/
        Live for yourself and you will live in vain. Live for others, and you will live again
          • 22963
          Re: toshiba 306
          Welcome!
          If I were to take a WAG, I would say that somebody installed a used logic board from a machine in a different speed range. CA20 is laser beam detection, and F901 is motor speed error. It would probably be desirable to find the original logic board and start there. =^..^=
          • chelsy11
            • Apr 2016
            • 7
            Re: toshiba 306
            Welcome!
            i buy a new board from the distributor, i put the old battery and the 8 pin ic, the machine gets ready now but when i try to copy it will scan the paper and go back to the ready mode without printing, wnd when i try to make a printout of counter it makes jam in registration. is there anything i missed?
              • 36995
              Re: toshiba 306
              Glad to have you join us.
              As bob marley said, post your problem in the correct technical forum. You will have a lot more Toshiba techs see it there.
