Kyocera 400ci - error code 4100
  • Ronbilog@gmail.com
    Hello, need help with Kyocera 400ci.
    is getting c4100 system error.
    it happened after cleaning all opc mc but ,Not sure if that could cause of getting c4100.
    anyone encounter this issue?
  • Aneurysm
    Administrator
    • Jan 2005
    • 1083
    Ronbilog@gmail.com, thanks for posting, we hope to see you back soon!
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: Kyocera 400ci - error code 4100
      Hi!
      This is check in area.Please post here:
      http://www.copytechnet.com/forums/ky...mita-copystar/
        • 23009
        This section is a great part of the forum to introduce yourself and tell us a little about you. You'll get more attention to your thread from the people that know about Kyocera by posting in the Kyocera Forum.
        As you probably already know C4100 is a beam detect error. We've had very few laser unit failures. Often though, a door interlock that flickers or does not close to 0 ohms can also give you beam detect errors, as can high voltage loss. =^..^=
