Hello & Help me
  • javanese
    • Jul 2018
    • 2
    Hello & Help me
    Hello there โœ‹๏ธ.. im newbie here, respect to yall.. bit i have a big problem on my Konica minolta c6501 & this problem was discussed before from somenone else but still no solution. im have a problem that has persisted for over 1 months now. I have a misregistration that is causing blurry text and seems to be mostly in the magenta. For example if I try to print black text (100/70/0/0) the text will be fine in some places on the sheet - but blurry in other places - sort of looks like a magenta drop shadow. I looks to be about 2 pixels off. The technicians have replaced lasers, belts but have made no progress in resolving the problem. They are thinking about changing the main image control board - but are trying to explore other options as this is a rather expensive part.
    I am hoping that someone here has had this problem and found a solution. i really stres bout it.
    Any advise or suggestions greatly appreciated.
    • 23009
    Re: Hello & Help me
    How about the registration roller and bearings? And you say the primary transfer belt assy was rebuilt or replaced? =^..^=
      • 37521
      Re: Hello & Help me
      Post you problem in the correct forum in order to get maximum exposure to KM techs. http://www.copytechnet.com/forums/konica-minolta/
