Hp laserjet p3015 13.01.00 error
  • zilins
    Replaced the pickup roller and separation pad for tray 2 last week. My customer called to complain paper jam problem was still there and said the printer was making squeaking noise from the back. Went to the customer and checked the printer. Inspected the tray 2 solenoid. The metal plate and the foam were not sticky. Tested print 50 sheets and couldn't duplicate the problem. The noise was there but not loud. I suspected it was from the fuser assembly ( i have lubricated the paper exit assembly). The fuser was replaced in may using refurbished parts. I am going to order a new paper registration assembly and fuser assembly and install them. Hope it will fix the 13.01.00 paper jam problem. The page count of this printer is about 415k. Event log shows the printer gets average 6 or 7 jams a day in this week. Am i in the right direction? Thanks.
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Hp laserjet p3015 13.01.00 error
    be sure to put some silocone grease on the rollers in the rear door and check the motion of the paper in the cassette is not rubbing as you feel the rising motion of the paper GOOD LUCK
      • 37521
      http://www.copytechnet.com/forums/hp/
      • nathicana
        • Aug 2008
        • 335
        I'm having to work on the same model with a 13.01.00 jam problem.
        Another technician worked on it, took it all apart and now there is a 59.30 no fuser rotation code.
        Do you know what fixed the jamming problem?
        • tsbservice
          Field tech
          • 8020
          This is wrong forum and I'm sure experienced tech like you know it.
          Post proper thread in HP subforums and Kiran, Lance and other HP pro techs will gladly help.
