Changing my Avitar
  • DM2-Inc
    • Sep 2020
    • 6
    Changing my Avitar
    I tried to add a image for my avatar. I can see it in my profile, but I don't see it when I create a Post.
    Am I doing something wrong?
    Re: Changing my Avitar
    here: https://www.copytechnet.com/forums/f...public_profile
    • ZOOTECH
      Senior member of CRS
      • 3375
      Yes😉
        • 37422
        After looking at your profile page it could be that your custom avatar is too large. Go to Settings - Edit Avatar. Under Custom Avatar Option 1 or 2 is the following statement "Note: The maximum size of your custom image is 150 by 150 pixels or 48.8 KB (whichever is smaller)." Your current avatar is 120 by 300 pixels. Use an imaging software such as IrfanView to crop the image. At about 120 by 120 you will get the head shoulders and the cork of the bottle.
          • 23002
          I believe that there are two avatars: The one that displays in the forums and the one that appears in your profile. And yes, there are size limitations and file type limitations.
          Note under Settings > Edit Profile Picture or Edit Avatar (two different things).
          • tsbservice
            Field tech
            • 7999
            Both of you are absolutely correct. I can just add that profile picture limitations are a bit lower than avatar - 200 by 300 pixels or 64.0 KB.
            • tsbservice
              Field tech
              • 7999
              OP try this.
