canon iR3570
  • edysetya
    • 6
    canon iR3570
    i have canon iR3570. there is a 1,5cm white blank on the top of paper when i use the A4 or A3 paper.
    any solution please?
    thanks.
    • 23006
    Can you attach a scan of the problem? =^..^=
    • edysetya
      • 6
      thanks for reply.
      this is a blackcopy with A4 paper, which there is a white blank on the top.
      And I have another problem with my ADF.
      When I use the ADF, image position on the result is shifted around 1 cm to the right (Y-axis). is there any adjustment should be done on the service mode menu?
      thanks.
      • edysetya
        • 6
        I'm sorry, I didn't understand with "run 50-10" and "run 50-12" ....how should I do?
          • 23006
          Sorry, I was thinking of a different model.
          Contact a service technichian. They'll know how to run service modes on your copier. I don't recommend that amateurs run service modes. =^..^=
          • edysetya
            • 6
            Ok. Thanks alot.
