Minolta CF1501; resetting meter after replacing fusing unit
  • mtbishay
    We recently replaced the fusing unit on our Minolta CF1501 and even though the new unit is in it displays that the fusing unit needs to be replaced. Does anyone know how to reset the meter for that unit? Any help will be greatly appreciated. Thanks
    Mary
  • Raymondd
    • Jan 2008
    • 108
    Was the fuser u installed new?
    • mtbishay
      Yes, it was new.
      • Raymondd
        • Jan 2008
        • 108
        If I remember correctly the machine should blow a fuse to reset the counter. The fuse should be located around the connector on the fuser. I think the fuse is a MCR-1/8 (could be wrong going off of an old memory!!!)
        Hope it helps...
        • mtbishay
          Thanks, I will check it out and let you know.
