removing user data (security risk) from hard drive in canon ir4570
  • uncle3gary
    • Aug 2025
    how do i
    remove user data (security risk) from hard drive in canon ir4570.
    as the copier is being sent to another department or school.
  • charm5496
    • 2387
    If it is at a high enough firmware version you go into additional functions>system settings>Initialize all data settings . If that option is not have your local service provider upgrade the machine to the latest firmware so you get that option. Otherwise you can always pull the HDD and buy a new one and have the firmware reloaded on it.
    good luck
    • uncle3gary
      good luck
      thanks
      i'll see if the additional functions is in the menu?
      we want to keep the machine working but clear all user data.
      i take it the machine will not function if the 'entire' drive is reformatted
      on a pc for instance.
      • charm5496
        • 2387
        no you would have to have a tech come out and reload the firmware for it to work again, but it would definetly clear off the data if done correctly.
